Transformers Rise of the Beasts Error
direwolf
Post by direwolf »
I seem to get a failure trying to rip Transformers.
Updated to the latest MKV version but no luck.
Attached the log file.
Thanks in advance!
MakeMKV v1.17.7 win(x64-release) started
Using LibreDrive mode (v01.0 id=1C080B0C438F)
Downloading latest HK to C:\Users\m_mis/.MakeMKV ...
Using Java runtime from C:\Program Files\Java\jre1.8.0_421\bin\java.exe
Title #00100.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00399.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00701.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01073.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00219.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01160.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01077.mpls has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00150.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00151.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01186.mpls was added as title #0
File 01187.mpls was added as title #1
File 01188.mpls was added as title #2
File 01189.mpls was added as title #3
File 01190.mpls was added as title #4
File 01191.mpls was added as title #5
File 01192.mpls was added as title #6
File 01193.mpls was added as title #7
File 01194.mpls was added as title #8
File 01195.mpls was added as title #9
Title #01196.mpls has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01197.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01198.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01199.mpls was added as title #10
Title #01200.mpls has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00149.mpls has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00040.mpls was added as title #11
Title #01072.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00509.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00510.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00511.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00512.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00513.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00514.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00515.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00516.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00505.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00517.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00518.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00519.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00520.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00521.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00506.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00507.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00500.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00501.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00503.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00508.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00522.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00523.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00524.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00525.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00526.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00527.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00528.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00529.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00530.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00531.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00532.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00533.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00534.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00535.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01081.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01086.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01087.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01090.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01093.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01096.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01099.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01104.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01105.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01106.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01107.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01108.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01109.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01110.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01111.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01112.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01113.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01114.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01115.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01116.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01117.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01118.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01119.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01120.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01121.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01122.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01123.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01124.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01125.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01126.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01127.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01128.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01129.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01130.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01131.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01132.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01133.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01134.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01135.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01136.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01137.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01138.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01139.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01140.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01141.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01142.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01143.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01144.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01145.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01146.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01147.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01148.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01149.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01150.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01151.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01152.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01153.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01154.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01155.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01156.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01157.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01158.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01159.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01161.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01162.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01163.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01183.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01184.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01185.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01202.mpls was added as title #12
Title #01205.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00801.mpls is equal to title 00040.mpls and was skipped
Title #00174.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00175.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00293.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00294.m2ts was added as title #13
Title #00340.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00496.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00460.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00462.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00418.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00466.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00493.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00461.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00492.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00437.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00485.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00447.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00487.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00428.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00481.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00449.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00488.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00434.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00484.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00451.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00489.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00432.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00483.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00467.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00494.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00459.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00491.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00440.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00486.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00477.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00495.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00452.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00490.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00429.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00482.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00501.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00502.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00503.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00498.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00505.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00499.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00506.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00500.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00507.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00508.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00509.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00510.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00511.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00512.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00513.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00514.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00524.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00557.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00515.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00525.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00516.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00526.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00517.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00527.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00518.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00528.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00519.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00529.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00520.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00530.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00521.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00531.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00522.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00532.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00523.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00533.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00534.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00535.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00536.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00537.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00560.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00561.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00562.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00563.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00564.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00565.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00566.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00567.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00568.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00569.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00570.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00571.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00572.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00573.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00574.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00575.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00576.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00577.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00578.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00558.m2ts has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00376.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00377.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00559.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00579.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00580.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00581.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00582.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00583.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00584.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00585.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00586.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00587.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00588.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00589.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00590.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00591.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00592.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00608.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00609.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00610.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Video/Transformers- Rise of the Beasts
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '32668778496'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '32668778496'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '32672317440'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '32672317440'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '32672772096'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom0' at offset '32672772096'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '32680704000'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom0' at offset '32680704000'
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '32681490432'
Error 'OS error - A device which does not exist was specified' occurred while reading '\Device\CdRom0' at offset '32681490432'
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '32681490432'
Error 'OS error - The volume for a file has been externally altered such that the opened file is no longer valid' occurred while reading '\Device\CdRom0' at offset '32681490432'
Failed to save title 11 to file C:/Video/Transformers- Rise of the Beasts/Transformers- Rise of the Beasts-FPL_MainFeature_t11.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Re: Transformers Rise of the Beasts Error
This is a read error, which can come from a number of causes. One is damage to the disk. Another is that the drive shut down during the read.
The more likely cause is the drive shutting down. Is it an external drive? A lot of external drives cannot run at full speed without sufficient power. Internal drives rarely have this happen.
direwolf wrote: Tue Sep 24, 2024 1:48 pm Hello,
Thanks in advance!
It appears the drive is having trouble reading the disc. Give it a good clean before trying to read again.
Stryker412
Post by Stryker412 »
Thanks in advance!
I'm having the same issue, were you able to finally rip this disc? I've tried two different drives and have cleaned the disc.
