X-Files: i want to believe
Benoit18
Hi there, another 20th century fox Bluray disc. Do you investigate how to fix the back up problem for this film ? Thanks in advance
Re: X-Files: i want to believe
Did you have a specific problem with this disk? Your message doesn't say.
Benoit18
Yes, sorry. My message wasn't clear. The disc is copied but when i want to open it the following message poped up : " the list is empty". I observed the same message with other discs and ripping firmware but makemkv solved this ...not for this one unfortunately. Thanks in advance.
