MakeMKV not working on macos Sequoia using on M3 Max
okizen
Post by okizen » Mon Sep 23, 2024 4:33 am
Is there a workaround to get the latest MakeMKV working on an m3 max using macOS Sequoia?
Re: MakeMKV not working on macos Sequoia using on M3 Max
Post by d00zah » Mon Sep 23, 2024 9:44 am
Since you've provided little detail as to HOW it's "not working", this is only a guess, but the author found it worthy of special mention:
Gatekeeper in macOS X 15 Sequoia
codykuphal
Post by codykuphal » Wed Oct 09, 2024 7:21 am
Is there a workaround to get the latest MakeMKV working on an m3 max using macOS Sequoia? Tiny Fishing
You can use Rosetta 2 to run applications that are not optimized for Apple Silicon, by installing Rosetta and opening MakeMKV through it. Check to see if there is a beta version of MakeMKV that is compatible with newer hardware. Also, make sure MakeMKV is granted full disk access in System Settings > Security & Privacy.
