jocke77
#1 Post by jocke77 » Tue Jun 09, 2020 10:41 am
If I get
LibreDrive firmware support is not yet available for this drive (id=C32B1C6CC46F)
Titleset id 2 is invalid
DEBUG: Code 0 at !g|`?-JJCvH7_aDw8:213130904
What does it mean? As I understand it, LibreDrive can be seen as some kind of codec used to decode / decrypt the "police code". Does it mean that there is no way do rip this specific DVD?
Current profile: DVD+R
Manufacturer: TSSTcorp
Product: DVDWBD SH-B123L
Revision: SB04
Drive platform: MT1939
Harware support: Yes
Firmware support: No
Firmware version: 03.31
DVD all regions: Possible, not yet enabled
BD raw data read: Possible, not yet enabled
BD raw metadata read: Possible, not yet enabled
Re: Status: Possible, not yet enabled
#2 Post by Billycar11 » Tue Jun 09, 2020 10:47 am
Libredrive does not really help DVDs you have another problem if you can't open that dvd libredrive is more for Blu-ray aacs and UHD ,disabling buss encryption.
jocke77
#3 Post by jocke77 » Tue Jun 09, 2020 4:06 pm
Billycar11 wrote: Tue Jun 09, 2020 10:47 am Libredrive does not really help DVDs you have another problem if you can't open that dvd libredrive is more for Blu-ray aacs and UHD ,disabling buss encryption.
Those are the only error messages I see. What could then be the problem?
#4 Post by Billycar11 » Tue Jun 09, 2020 10:56 pm
Something to do with these 2
jonghotti
#5 Post by jonghotti » Wed Jun 10, 2020 5:21 am
jocke77 wrote: Tue Jun 09, 2020 10:41 am If I get
It means please purchase another drive, one that works, Billy or I can help you with that if needed. Thank you.
jocke77
#6 Post by jocke77 » Fri Jun 12, 2020 4:52 pm
Buying another drive is not an option. Any other suggestions are welcome.
If, for instance, VLC can show the movie, why can't makemkv handle it?
martinbrady
#7 Post by martinbrady » Fri Jun 12, 2020 6:26 pm
jocke77 wrote: Fri Jun 12, 2020 4:52 pm Buying another drive is not an option. Any other suggestions are welcome.
because MKV does more than VLC and is a lot more complex, I mean, VLC plays most dvds (just a matter of zone problems for a small number of them) , ripping is a lot tougher than playing, and MKV cannot handle a MKV non compatible drive, MKV is not a player like VLC
if the reply you got says it has to be changed for a MKV handling, it certainly must be changed, given the signature of the guy who answered you (jonghotti), it's no fun but... :(
and excuse my english which might be funny
please don't mention the quality of my english unless I'm obscure :wink:
jonghotti
#8 Post by jonghotti » Sun Jun 14, 2020 7:28 am
Another suggestion is to use a different ripping program, one that supports that drive. MakeMKV obviously does not.
Classicaldonkey
#9 Post by Classicaldonkey » Mon Sep 16, 2024 1:20 pm
Sorry to ask, but I am confused by it all
I get “Using LibreDrive mode” then after that I get “Using direct disc mode”
Is it working right?
tommik128
#10 Post by tommik128 » Fri Sep 20, 2024 8:54 pm
Normally you do not need libredrive enabled unit to rip dvds, as said above. MakeMKV should rip DVDs just fine. But he is getting that error, so his drive is not supported. He will have to get a supported one if he plans to use MakeMKV, for example ASUS BW-16D1HT rips DVDs even when it is not libredrive enabled I can confirm that.
zaqqaz6917
#11 Post by zaqqaz6917 » Sun Sep 22, 2024 9:18 pm
For dvd use a free ripper shrinker like dvd shrink
#12 Post by Coopervid » Sun Sep 22, 2024 10:51 pm
zaqqaz6917 wrote: Sun Sep 22, 2024 9:18 pm For dvd use a free ripper shrinker like dvd shrink
Welcome to the 1990ies.
