When does Makemkv support the drive Pioneer BDR-S13EBK
Lehmeier
Post by Lehmeier » Sat Sep 14, 2024 7:56 pm
Hello!
I bought a Pioneer BDR-S13EBK and realised that it does not work with MakeMKV.
When will a new firmware be available and when will it work with MakeMKV?
Whenever I start MakeMKV v 1.17.1 linux ( x64-release ) it says that 1.17.7 is too old and I should download the latest version. But the 1.17.7 is up to date.
It also says: ‘Load current SDF in /home/ralf/.MakeMKV ...’
But I cannot find an SDF file in /home/ralf/.MakeMKV.
And under the information :
Device : SG:dev_21:0
BDR-S13U 1.04 CGDL001019WL
And at some point the message ‘Error occurred, programme is terminated.’ appears.
This is all very strange. I haven't registered / bought the programme yet, because I haven't been able to test it - but that shouldn't really be the cause.
Does anyone have any ideas that might help?
Yours sincerely, R.Lehmeier
Translated with DeepL.com (free version)
My System :
inxi -Fxxxz
System:
  Kernel: 6.10.9-arch1-2 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: tsc
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: plank,xfce4-panel tools: xfce4-screensaver vt: 2 dm: SDDM
    Distro: EndeavourOS base: Arch Linux
Machine:
  Type: Desktop Mobo: Gigabyte model: X670 AORUS ELITE AX v: x.x
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: F32b date: 09/03/2024
CPU:
  Info: 12-core model: AMD Ryzen 9 7900X bits: 64 type: MT MCP MCM
    smt: enabled arch: Zen 4 rev: 2 cache: L1: 768 KiB L2: 12 MiB L3: 64 MiB
  Speed (MHz): avg: 2178 high: 5438 min/max: 545/5733 cores: 1: 3392 2: 4081
    3: 4410 4: 545 5: 545 6: 545 7: 4889 8: 545 9: 3572 10: 4736 11: 5015
    12: 4424 13: 545 14: 545 15: 5438 16: 545 17: 545 18: 545 19: 545 20: 4708
    21: 545 22: 545 23: 545 24: 545 bogomips: 225240
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
  Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
    vendor: Sapphire PULSE driver: amdgpu v: kernel arch: RDNA-3 pcie:
    speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
    empty: HDMI-A-1,HDMI-A-2,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c
    class-ID: 0300
  Device-2: AMD Raphael vendor: Gigabyte driver: amdgpu v: kernel
    arch: RDNA-2 pcie: speed: 16 GT/s lanes: 16 ports: active: none empty: DP-3,
    DP-4, DP-5, HDMI-A-3, Writeback-2 bus-ID: 17:00.0 chip-ID: 1002:164e
    class-ID: 0300 temp: 50.0 C
  Device-3: SunplusIT Depstech webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 3-5:2 chip-ID: 1bdf:5050
    class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: xfwm4 v: 4.18.0 driver: X: loaded: amdgpu
    unloaded: modesetting,radeon alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5375x1511 s-dpi: 96 s-size: 1422x400mm (55.98x15.75")
    s-diag: 1477mm (58.16")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right
    model: Samsung U32J59x serial: <filter> res: 2688x1512 hz: 60 dpi: 98
    size: 697x392mm (27.44x15.43") diag: 800mm (31.5") modes: max: 3840x2160
    min: 720x400
  Monitor-2: DP-2 mapped: DisplayPort-1 pos: left model: Samsung U32J59x
    min: 720x400
  API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
    navi31 LLVM 18.1.8 DRM 3.57 6.10.9-arch1-2) device-ID: 1002:744c
  API: Vulkan v: 1.3.295 layers: 9 surfaces: xcb,xlib device: 0
    type: discrete-gpu driver: amd device-ID: 1002:744c device: 1
    type: integrated-gpu driver: amd device-ID: 1002:164e
Audio:
  Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
    speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: 17:00.1 chip-ID: 1002:1640
    class-ID: 0403
  Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
    bus-ID: 17:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: SunplusIT Depstech webcam driver: snd-usb-audio,uvcvideo
  Device-5: C-Media Audio Adapter (Unitek Y-247A)
    driver: cmedia_hs100b,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 bus-ID: 9-1.4:6 chip-ID: 0d8c:0014 class-ID: 0300
  API: ALSA v: k6.10.9-arch1-2 status: kernel-api
  Server-1: sndiod v: N/A status: off
  Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin
    4: pw-jack type: plugin
Network:
  Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: speed: 5 GT/s lanes: 1 port: e000 bus-ID: 10:00.0 chip-ID: 10ec:8125
    class-ID: 0200
  IF: enp16s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e v: kernel pcie: speed: 5 GT/s lanes: 1 bus-ID: 11:00.0
    chip-ID: 14c3:0616 class-ID: 0280
  IF: wlan0 state: down mac: <filter>
Bluetooth:
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 bus-ID: 3-7:4 chip-ID: 0e8d:0616 class-ID: e001
    serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
    rfk-block: hardware: no software: no address: N/A
Drives:
  Local Storage: total: 5.46 TiB used: 1.73 TiB (31.6%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO 2TB size: 1.82 TiB
    speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7
    temp: 51.9 C scheme: GPT
  ID-2: /dev/sda vendor: Western Digital model: WD40EFRX-68N32N0
    size: 3.64 TiB type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 tech: HDD rpm: 5400
    serial: <filter> fw-rev: 1021 scheme: GPT
Partition:
  ID-1: / size: 195.31 GiB used: 53.36 GiB (27.3%) fs: btrfs
    dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 2 GiB used: 584 KiB (0.0%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-3: /home size: 1.63 TiB used: 1.46 TiB (89.8%) fs: btrfs
    dev: /dev/nvme0n1p3
  ID-4: /var/log size: 195.31 GiB used: 53.36 GiB (27.3%) fs: btrfs
    dev: /dev/nvme0n1p2
Swap:
  Alert: No swap data was found.
Sensors:
  System Temperatures: cpu: 67.6 C mobo: 40.0 C
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 54.0 C mem: 61.0 C fan: 0 watts: 28.00
    device: amdgpu temp: 51.0 C
Info:
  Memory: total: 128 GiB note: est. available: 124.92 GiB
    used: 7.57 GiB (6.1%)
  Processes: 508 Power: uptime: 4h 24m states: freeze,mem,disk suspend: deep
    wakeups: 0 hibernate: platform Init: systemd v: 256 default: graphical
  Packages: 2346 pm: pacman pkgs: 2341 pm: flatpak pkgs: 5 Compilers:
    clang: 18.1.8 gcc: 14.2.1 Shell: Bash v: 5.2.32 running-in: yakuake
    inxi: 3.3.35
segfaulted
Re: When does Makemkv support the drive Pioneer BDR-S13EBK
Post by segfaulted » Sat Sep 14, 2024 9:18 pm
Lehmeier wrote: Sat Sep 14, 2024 7:56 pm Whenever I start MakeMKV v 1.17.1 linux ( x64-release ) it says that 1.17.7 is too old and I should download the latest version. But the 1.17.7 is up to date.
This is a known issue which should be fixed soon. For now, you can click on Register and use the free beta key from viewtopic.php?f=5&t=1053
BDR-S13U 1.04
The drive firmware is too new which blocks LibreDrive and the ability to rip 4K blu-ray discs. No one knows when that will be fixed. Until then, the drive is good for ripping regular blu-ray and DVDs.
The data is stored inside _private_data.tar, which should start around 2MB if the SDF data was downloaded successfully.
Lehmeier
Post by Lehmeier » Sat Sep 21, 2024 7:58 pm
Then I hope that there will soon be a firmware that supports my drive.
After using the free key, I was able to save a Bluray film as a backup, but it couldn't save a UHD film.
So unfortunately Makemkv is only worth half as much to me.
Because backing up my UHD films was the reason why I bought this drive.
If Makemkv made it possible to back up UHD films, I would be inclined to buy Makemkv.
Post by Coopervid » Sat Sep 21, 2024 8:19 pm
Lehmeier wrote: Sat Sep 21, 2024 7:58 pm Then I hope that there will soon be a firmware that supports my drive.
No. Your drive is too new and is crippled by Pioneer. You need to buy a drive that has firmware before December 2022. Check the sellers side or write a PM to me.
Post by MartyMcNuts » Sat Sep 21, 2024 11:14 pm
It's not MakeMKV that is the issue. It is your drive. You should have checkd the UHD guide and purchased a compatible drive. We have been waiting more than a year and a half so far for support for Pioneer's with newer firmware and still no idea if/when it will ever happen.
Return your drive and get one that is currently UHD compatible.
Lehmeier
Post by Lehmeier » Sun Sep 22, 2024 4:59 pm
I've had it too long for that - about 4 months.
But what interests me more. Does the sound work on all devices?
I tried to play a film (Bakaroo Banzai), which I had copied as a test, on my TV via a NAS.
The picture was played back, but the sound was not supported. The film was in .mpg format.
Will this improve?
Post by Coopervid » Sun Sep 22, 2024 10:33 pm
Lehmeier wrote: Sun Sep 22, 2024 4:59 pm
Will this improve?
The problem is located between the keyboard and the monitor.
Post by MartyMcNuts » Sun Sep 22, 2024 11:05 pm
Will this improve?
Yeah, you should use either MP4 or mkv (preferred) not mpg.
Post by dcoke22 » Mon Sep 23, 2024 3:41 pm
Lehmeier wrote: Sun Sep 22, 2024 4:59 pm But what interests me more. Does the sound work on all devices?
Will this improve?
MakeMKV just copies what's on the disc so usually when people have trouble with sound, it is almost always something in their playback setup that is the trouble. There's a handy utility called MediaInfo that can show you lots of details about what's in your .mkv files (and other formats). DVDCompare.net says that the blu-ray of Buckaroo Bonzai has DTS-HD Master Audio. In an effort to save money, some TVs, sound bars, etc. don't support DTS audio. I don't know, obviously, if that's the case with your setup, but it is a good place to start.
