Hey Coopervid,
also looking to rip UHD.
Laufwerksinformation:
OS-Gerätename: \Device\CdRom1
Aktuelles Profil: DVD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer:
Firmware-Datum: 2020-06-15
LibreDrive Information:
Drive platform: RS8511
Firmware version: 1.14
thx
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
PM sent.Fatal0l wrote: Fri Sep 20, 2024 7:28 pm Hey Coopervid,
Produzent: PIONEER
Revision: 1.14
Serienummer:
thx
lenkaw
Hi there,
I too have similar drive information to what others have posted, and was wondering if it's possible to flash my drive in a similar way.
Thank you in advance for the help!
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: xxxx
Firmware date: 2020-06-15
OS device name: E:
Revision: 1.14
Serial number: xxxx
PM is coming.lenkaw wrote: Sun Sep 22, 2024 1:18 am Hi there,
OS device name: E:
Revision: 1.14
Serial number: xxxx
Upload8
Same BD-Riper bought in Germany as External Ripper may I receive a PM too?
Kind Regards
me
OS-Gerätename: /dev/sr0
Aktuelles Profil: BD-ROM
Produzent: ASUS
Produkt: SBW-06D5H-U
Revision: E101
Serienummer: [redacted]
Firmware-Datum: 2018-08-22
Highest AACS version: 33
Firmware version: E101/ID26
me
lenkaw
Thank you very much, Coopervid!Coopervid wrote: Sun Sep 22, 2024 9:36 amPM is coming.lenkaw wrote: Sun Sep 22, 2024 1:18 am Hi there,
OS device name: E:
Revision: 1.14
Serial number: xxxx
The guide was very easy to follow and I was able to flash my drive. I tested a 4K disc and confirmed that it can be read. Thank you again for your help!
PM sent.Upload8 wrote: Sun Sep 22, 2024 1:00 pm Same BD-Riper bought in Germany as External Ripper may I receive a PM too?
Kind RegardsCode: Select all
Laufwerksinformation OS-Gerätename: /dev/sr0 Aktuelles Profil: BD-ROM Produzent: ASUS Produkt: SBW-06D5H-U Revision: E101 Serienummer: [redacted] Firmware-Datum: 2018-08-22 Markierungen der Bus-Verschlüsselung: 1B Highest AACS version: 33 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: E101/ID26 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
me
CaptainNorwegia
Hey Cooper!
First time caller, long time listener. Can you assist in patching my UD-03?
OS device name: I:
Revision: 1.14
Serial number: nunya business
Highest AACS version: 65
Hopefully I did my research right lol. Thank you in advance!
LeBref
Can I please also receive the procedure for flashing my disk?
And possibly a link to a firmware update. I'm only on V1.11
Revision: 1.11
Serial number: [redacted]
Firmware date: 2018-11-28
Highest AACS version: 76
Firmware version: 1.11
Unrestricted read speed: Yes-
PM is coming.CaptainNorwegia wrote: Wed Sep 25, 2024 4:37 amHey Cooper!
OS device name: I:
Revision: 1.14
Check your PM.LeBref wrote: Wed Sep 25, 2024 10:16 am Hi,
Drive Information OS device name: \Device\CdRom0 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.11 Serial number: [redacted] Firmware date: 2018-11-28 Bus encryption flags: 1B Highest AACS version: 76 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.11 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
LeBref
It Works \o/
Thank you
Thank you
jmack76
Newbie here, I would love any help on my Verbatim 43890 to help make it UHD if it is possible.
Revision: 1.14
Highest AACS version: 81
Thank you in Advance!
I Also have an LG WH16NS40 if it would work?
OS device name: F:
Product: BD-RE WH16NS40
Revision: 1.02
Firmware date: 2115-12-11 14:59
Firmware version: 1.02
Thank you
Revision: 1.14
OS device name: F:
Revision: 1.02
Thank you
CaptainNorwegia
Works! Many thanks
PM sent regarding the Pioneer.jmack76 wrote: Wed Sep 25, 2024 7:52 pm Newbie here, I would love any help on my Verbatim 43890 to help make it UHD if it is possible.
Revision: 1.14
OS device name: F:
Revision: 1.02
Thank you
Regarding the LG read here how to flash it:
viewtopic.php?f=16&t=19634
