Create ISO Backups
g0ren
Create ISO Backups
Post by g0ren » Sat Mar 30, 2024 9:51 pm
Hello, I like to make full disc backups of all my Blu-rays and DVD's. MakeMKV makes DVD's into ISO files, but Blu-ray's into BDMV folders, which I then have to use something like Keka to turn into an ISO file. ISO's are a bit more convenient for my use and I'd like to skip the conversion step, so I'm wondering if there's a setting in MakeMKV to make Blu-ray's into ISO's directly? I couldn't find anything poking around in the settings.
Re: Create ISO Backups
Post by dcoke22 » Sat Mar 30, 2024 11:43 pm
You're correct. ISOs for DVDs and BDMV folders for blu-rays and UHDs. There's no setting to let MakeMKV create ISOs for blu-rays; you have to use another program to convert.
g0ren
Post by g0ren » Sun Mar 31, 2024 1:21 am
Is there a way to request the feature for a possible future version, or have the devs already explained why they won't implement it?
Post by dcoke22 » Sun Mar 31, 2024 2:20 am
Posting on the forum is probably the best way to request the feature be added. If Mike has explained himself on this topic, I'm not aware of it (but there are a lot of posts on this forum that I've never read).
MakeIt-EASY
Post by MakeIt-EASY » Sun Sep 22, 2024 7:39 am
What software is everybody using to make ISO then?
Post by dcoke22 » Sun Sep 22, 2024 9:46 pm
I seem to recall Imgburn being recommended.
Post by Coopervid » Sun Sep 22, 2024 10:56 pm
It's MacOS. And people need to ask Google.
Post by dcoke22 » Mon Sep 23, 2024 3:28 pm
The hard part about creating ISOs of blu-rays on macOS is that macOS does not natively support version of filesystem used on blu-rays, UDF.
As Steve Jobs once famously said, blu-ray is a bag of hurt. 15 years later and macOS natively still can't play a blu-ray disc.
Post by Coopervid » Mon Sep 23, 2024 3:34 pm
Ouch! I didn't know that.
