Post by RESET_9999 » Sat Sep 14, 2024 12:02 am
there might be some devices that use L6 when they decode DV as HDR10 but otherwise, it's pretty much useless.
jayper
Post by jayper » Sun Sep 15, 2024 1:21 am
RESET_9999 wrote: Sat Sep 14, 2024 12:02 am there might be some devices that use L6 when they decode DV as HDR10 but otherwise, it's pretty much useless.
Thanks very much!
jayper
Post by jayper » Sun Sep 15, 2024 4:54 pm
Sorry, follow-up question. If you're watching DV content, with updated L6, on an HDR10-only device. Does it even matter? Or is it only something that a DV device can use? And if you are on a DV-capable device, and playing back in DR10, is it better to update the L6 or not? Sorry... I clearly need to do more reading on L6.
Appreciate the guidance!
Post by RESET_9999 » Mon Sep 16, 2024 12:49 am
if the device sends the static L6 metadata to the TV, yes. For example, on the ugoos, unless you specify an HDR10 string in the menu, it sends LLDV in HDR10 without static metadata which is not ideal. Preferably, you want to send a maxcll or MDL value that matches your EDID target so the TV can use the best static tone mapping curve for the image brightness it receives.
However, it also depends on whether your TV uses MDL or maxcll for HDR10.
staknhalo
Post by staknhalo » Mon Sep 16, 2024 8:50 pm
Here's a DV profile 4? (SDR HEVC BL?) file I came across from someone linking on Plex forums:
https://mega.nz/file/QGRwQQQB#_3ErgcM5Y ... UTE8eau8Tc
DylanValenti
Post by DylanValenti » Fri Sep 20, 2024 12:33 am
Trying to export FEL screenshots without an nvidia gpu but it's not working. It says that it exports the screenshots but the folder doesn't have any in it. I downloaded the latest tool pack and ffms2 is in it, so any idea what's going on here?
Post by RESET_9999 » Fri Sep 20, 2024 2:42 am
idk, did you install avisynthplus ?
https://github.com/AviSynth/AviSynthPlu ... redist.exe
DylanValenti
Post by DylanValenti » Fri Sep 20, 2024 6:12 am
RESET_9999 wrote: Fri Sep 20, 2024 2:42 am idk, did you install avisynthplus ?
Yep. Just reinstalled to verify. Still no screenshots
Post by RESET_9999 » Fri Sep 20, 2024 11:04 am
idk , works fine for me. Try in manual mode, go into the temp folder and try to play the .avs script in avspmod, it will tell you the error.
DylanValenti
Post by DylanValenti » Fri Sep 20, 2024 4:11 pm
It says "Cannot load file 'Z:/01DoVi/tools/avs_libplacebo.dll'. Platform returned code 126: The specified module could not be found. (Z:\01DoVi\temp.folder25\9_FEL.avs, line 2)"
I checked my tools folder and avs_libplacebo.dll is indeed in the root. Any suggestions?
Post by RESET_9999 » Fri Sep 20, 2024 4:45 pm
no idea, works fine for me but i just noticed that there is an issue with the HDR10 Base layer SDR tone-mapped screenshots in that workflow which is unrelated to your issue and is now fixed in latest beta. Anyway, I dont see the point in comparing HDR images in SDR(this is not lossless). The script outputs proper HDR metadata for the HDR screenshots which can be viewed in HDR (or mapped to SDR) on Chrome/Edge/Opera browser. EG: https://slow.pics/c/bTBjYZuB Also, ffms2 for my screenshots workflow (7-1) is quite slow so not really usable IMO. When you encode in 8-2-1, it's fine.
staknhalo
Post by staknhalo » Fri Sep 20, 2024 5:52 pm
staknhalo wrote: Mon Sep 16, 2024 8:50 pm Here's a DV profile 4? (SDR HEVC BL?) file I came across from someone linking on Plex forums:
I'm removing this, MEGA started throttling my account ever since I posted it lol - I can't download my 8K movie trailers that get posted to MEGA because of 'account usage' 😭
Edit: It's from here - the 'LG' one IIRC - https://www.demolandia.net/4k-video-tes ... age-2.html
Post by RESET_9999 » Fri Sep 20, 2024 6:05 pm
Yeah, I have speed issues with MEGA all the time. I hate it.
skull88
Post by skull88 » Fri Sep 20, 2024 6:10 pm
FWIW, when that happens to me, I just briefly turn on VPN and it seems to usually let the file download fast again, at least with JDownloader2 and a paid MEGA account. Cheers.
staknhalo
Post by staknhalo » Fri Sep 20, 2024 9:18 pm
skull88 wrote: Fri Sep 20, 2024 6:10 pma paid MEGA account
Appreciate the tip though :P
