Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
rg_63
This is my first post in this forum.
Before posting I tried to find a solution for my problem by reading many topics in this forum.
But unfortunately I was not successful and could not find a solution.
I like to start ripping my UHD Bluray collection to my Windows-PC.
I have a Pioneer BDR-S09XLT drive.
Here is the output from makemkv:
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.31
Serial number:
Firmware date: 2015-05-25
Highest AACS version: 20
Drive platform: RS8600
Firmware version: 1.31/ID43
But I am not able to rip UHD-discs.
MakeMKV says that there is no disc inserted.
In other topics in this forum I read that it is likely that the drive must be cross flashed.
But I also read that there is no official public flashing tool for Pioneer drives.
I am not sure what I have to do to get my drive working for ripping UHD-BluRays.
Revision: 1.31
Serial number:
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Your firmware does not support UHD ripping. The drive itself may, with updated-to-after-UHD-was-introduced firmware.
Expect a private message from one of the people who can help you with that.
Please post again. Most people asking for something like this just disappear.rg_63 wrote: Sat Aug 10, 2024 9:12 pm This is my first post in this forum.
Revision: 1.31
Serial number:
rg_63
I had email contact with Billycar11 and I have got the flasher tool for my drive.
I flashed the drive und now it can read UHD-discs.
Everything is working without problems now.
mangusng
It's my 1st post too. And I got the same drive:
OS device name: E:
Revision: 1.52
Serial number: XXXXXXXX
Firmware date: 2019-01-11
Firmware version: 1.52/ID43
Could you, please, help me with UHD?
OS device name: E:
Revision: 1.52
Check your PM.mangusng wrote: Tue Aug 13, 2024 9:42 pm Hi,
OS device name: E:
Revision: 1.52
mangusng
Thx.
Got you msg, downloaded and executed without issues.
Working excellent. Thank you!
akkk44
Greetings:
I have also got a BDR-S09XLT drive recently, could kind souls here help me? Many thanks!
You need to post your Makemkv info to check if it‘s possible to flash this drive.akkk44 wrote: Sat Sep 14, 2024 8:58 pm Greetings:
Mippo101
Greetings! Luckily i've got one of those Pioneers in my old PC too. Is my drive flashable?
Thank you.
Thank you.
OS device name: G:
Revision: 1.10
Firmware date: 2013-10-15
Firmware version: 1.10/ID43
No disc inserted-
Yes.PM sent.Mippo101 wrote: Mon Sep 16, 2024 4:36 pm Greetings! Luckily i've got one of those Pioneers in my old PC too. Is my drive flashable?
Thank you.
Drive Information OS device name: G: Manufacturer: PIONEER Product: BD-RW BDR-S09 Revision: 1.10 Serial number: XXXXXX Firmware date: 2013-10-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.10/ID43 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
Mippo101
Worked flawlessly, thank you Coopervid!
Megastorm
Good morning,
can you help me activate UHD playback with my player.
I can't find anything about the flash software or
I simply want to play my 4K Blurays on my PC
thanks in advance.
Informations lecteur
Nom du lecteur SE : D:
Fabricant : PIONEER
Produit : BD-RW BDR-S09
Révision : 1.55
Numéro de série : xxxxxxxx
Date micrologiciel : 2023-02-03
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 61
Drive platform: Pioneer RS8601
Firmware version: ID43
Aucun disque
thanks in advance.
Fabricant : PIONEER
Révision : 1.55
Aucun disque
Firmware is locked in your drive, not up- or side-gradable.Date micrologiciel : 2023-02-03
Ultrapanavision
I also got this drive and asking kindley if someone can send me the data to flash.
Thank you very much in advance.
Revision: 1.31
Serial number: xxxxxxxx
Highest AACS version: 81
Revision: 1.31
