Cannot backup DVD but can save titles. Here's the debug output:
MakeMKV v1.6.14 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/Eccles/MakeMKV_log.txt
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-857E ZF1E" opened in DASPI v1.3 mode.
Optical drive "BD-RE ASUS SBW-06C1S-U C101" opened in DASPI v1.3 mode.
Title #0 has length of 18 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Can't locate a cell for VTS 1 TTN 2 PGCN 2 PGN 1
Title #2 has length of 5 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #3 has length of 5 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #4 has length of 5 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #5 was added (14 cell(s), 1:27:56)
Title #6 was added (3 cell(s), 0:06:56)
Title #7 was added (11 cell(s), 0:09:24)
Title #8 has length of 87 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #9 has length of 87 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #10 has length of 113 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #11 has length of 67 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #12 was added (1 cell(s), 0:02:53)
Title #13 was added (10 cell(s), 0:12:55)
Title #14 was added (1 cell(s), 0:02:26)
Title #15 was added (1 cell(s), 0:04:54)
Title #16 has length of 93 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #17 has length of 56 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #18 was added (1 cell(s), 0:02:24)
Title #19 was added (10 cell(s), 0:08:09)
Title #20 has length of 78 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #21 was added (1 cell(s), 0:02:27)
Title #22 has length of 73 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #23 has length of 86 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #24 has length of 73 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #25 was added (11 cell(s), 0:09:33)
Title #26 has length of 53 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #27 has length of 78 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #28 was added (1 cell(s), 0:02:52)
Title #29 has length of 81 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #30 was added (1 cell(s), 0:02:40)
Title #31 was added (11 cell(s), 0:12:49)
Title #32 was added (1 cell(s), 0:02:13)
Title #33 has length of 94 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #34 was added (1 cell(s), 0:05:21)
Title #35 has length of 78 seconds which is less than minimum title length of 121 seconds and was therefore skipped
Title #36 has length of 51 seconds which is less than minimum title length of 121 seconds and was therefore skipped
DEBUG: Code 1571 at [>a{Yff]psdpCqBw_s<H[:213133250
DEBUG: Code 3 at [>a{Yff]psdpCqBw_s<H[:213133250
DEBUG: Code 1347 at [>a{Yff]psdpCqBw_s<H[:213133250
Backup Disabled 1.6.14
- Contact:
Re: Backup Disabled 1.6.14
Unfortunately, it's by design - MakeMKV can do full disc backup only for blu-rays.
