Disney DVD Issues-Finding Nemo
den878
Post by den878 »
I have issues when opening DisneyDVD's. MakeMKV only finds the previews. Below are the log files I recieved when trying to read Finding Nemo dvd but it is similar to all my disney dvd's. Any help would be appreciated
MakeMKV v1.17.7 win(x64-release) started
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
Calculated BUP offset for VTS #7 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Calculated BUP offset for VTS #12 does not match one in IFO header.
Calculated BUP offset for VTS #13 does not match one in IFO header.
Calculated BUP offset for VTS #14 does not match one in IFO header.
Calculated BUP offset for VTS #15 does not match one in IFO header.
Calculated BUP offset for VTS #16 does not match one in IFO header.
Calculated BUP offset for VTS #17 does not match one in IFO header.
Calculated BUP offset for VTS #18 does not match one in IFO header.
Calculated BUP offset for VTS #19 does not match one in IFO header.
Calculated BUP offset for VTS #20 does not match one in IFO header.
Calculated BUP offset for VTS #21 does not match one in IFO header.
Calculated BUP offset for VTS #22 does not match one in IFO header.
Calculated BUP offset for VTS #29 does not match one in IFO header.
Calculated BUP offset for VTS #30 does not match one in IFO header.
Calculated BUP offset for VTS #31 does not match one in IFO header.
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading 'DVD+R-DL Optiarc DVD RW AD-7241S 1.03 Ll1022H0cbO1' at offset '3543744512'
Cells 1-8 were removed from title start
Cells 163-163 were removed from title end
Title #11 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Title #12 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Title #14 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Title #16 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Title #18 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Title #20 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Title #24 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Title #25 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Cells 1-6 were removed from title start
Complex multiplex encountered - 22 cells and 1621 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #27 (1:36:07) was skipped due to navigation error
Title #28 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Title #30 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Title #31 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Title #32 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Title #35 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Title #36 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Title #37 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Title #38 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Title #39 declared length is 1:34:35 while its real length is 0:32:23 - assuming fake title
Cells 161-161 were removed from title end
Title #44 declared length is 1:34:11 while its real length is 0:31:43 - assuming fake title
Title #46 declared length is 1:34:11 while its real length is 0:31:43 - assuming fake title
Title #47 declared length is 1:34:11 while its real length is 0:31:43 - assuming fake title
Title #56 declared length is 1:34:11 while its real length is 0:31:43 - assuming fake title
Title #57 (1:35:42) was skipped due to navigation error
Title #59 declared length is 1:34:11 while its real length is 0:31:43 - assuming fake title
Title #62 declared length is 1:34:11 while its real length is 0:31:43 - assuming fake title
Title #66 declared length is 1:34:11 while its real length is 0:31:43 - assuming fake title
Title #67 declared length is 1:34:11 while its real length is 0:31:43 - assuming fake title
Title #70 declared length is 1:34:11 while its real length is 0:31:43 - assuming fake title
Title #71 has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #72 has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 14-14 were removed from title end
Complex multiplex encountered - 2 cells and 174 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #73 was added (9 cell(s), 0:05:46)
Angle #2 was added for title #73
Angle #3 was added for title #73
Cells 6-6 were removed from title end
Title #74 was added (5 cell(s), 0:04:41)
Fake cells occupy 34% of the title - assuming fake title
Title #76 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #78 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #79 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #80 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #81 has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #82 has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #83 has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #84 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #85 was added (1 cell(s), 0:02:59)
Title #86 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #87 has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Fake cells occupy 44% of the title - assuming fake title
Title #90 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #90/1 has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #90/2 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #90/3 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #92 has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #93 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Re: Disney DVD Issues-Finding Nemo
MakeMKV has different Opening Modes for DVDs. Maybe one of them will help?
