BDR-XS07S UHD Flash
Re: BDR-XS07S UHD Flash
Post by Woodstock » Mon Aug 19, 2024 7:15 pm
CompletelyLawless wrote: Mon Aug 19, 2024 6:30 pm There is no way to downgrade to 1.01 if I locate a copy of that firmware?
If you could figure out how to install an older version of the software, there are a LOT of people who would want to talk to you. Unfortunately, it seems that any drive built on or after 12/22/2022 has had its firmware locked, and it would take replacing chips to fix it.
jhnkane
Post by jhnkane » Mon Aug 19, 2024 11:02 pm
Woodstock wrote: Mon Aug 19, 2024 7:15 pm
has anyone posted their attempt on an external flash? id be interested to help (try myself) but i am not willing to teardown my own drive.
:D
BDR-XS07S and DP-UB9000P1K
Post by MartyMcNuts » Mon Aug 19, 2024 11:14 pm
jhnkane wrote: Mon Aug 19, 2024 11:02 pm
Many things have been tried and failed. This has been an issue that we have been looking into for the past 18+ months.
jhnkane
Post by jhnkane » Mon Aug 19, 2024 11:49 pm
MartyMcNuts wrote: Mon Aug 19, 2024 11:14 pm
thanks Marty. i understand the complexity. im interested in bypassing the new firmware's write protections. ill plan to report back if i come up with anything but first i need to find a broken/for parts drive to work with.
:D
Post by Coopervid » Tue Aug 20, 2024 7:18 pm
jhnkane wrote: Mon Aug 19, 2024 11:49 pm
Read here.
https://github.com/rpc1dev/DVRFlash
This was the skunk works. SCSI commands using Winaspi. You just can't access the firmware chip directly or do you think that an average user will take his drive apart to connect a programmer to the chip to flash the firmware?
jhnkane
Post by jhnkane » Tue Aug 20, 2024 7:33 pm
ya i dont think anyone is suggesting that the solution is tearing their drive apart. thanks thou mr Cooper
:D
Post by Coopervid » Tue Aug 20, 2024 9:10 pm
jhnkane wrote: Tue Aug 20, 2024 7:33 pm ya i dont think anyone is suggesting that the solution is tearing their drive apart. thanks thou mr Cooper
The people who worked on this are no idiots. Good luck if you want to pick up this task.
mdeshaun
Post by mdeshaun » Tue Aug 27, 2024 11:23 pm
Based on the data from MakeMKV, it looks like my drive is flashable. Can someone point me in the direction of how to flash the UHD firmware?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number: [redacted]
Firmware date: 2020-09-03
Bus encryption flags: 13
Drive platform: RS8E20
Firmware version: 1.01
Post by Coopervid » Wed Aug 28, 2024 9:14 am
mdeshaun wrote: Tue Aug 27, 2024 11:23 pm Based on the data from MakeMKV, it looks like my drive is flashable. Can someone point me in the direction of how to flash the UHD firmware?
OS device name: E:
Revision: 1.01
Read your PM.
flojo
Post by flojo » Thu Sep 12, 2024 12:44 pm
Could you PM the link too? I just picked one up.
Just by holding this it feels cheap. Who actually manufacturers the Pioneer USB slim drives and are they the same quality as their 5.25 drives?
I know Pioneer outsources most or all electronics today. For instance I have a PLX-1000 record player and while it is very good, it's not fabricated or designed by Pioneer. I know that their original 3.25 floppy drives were Toshiba although I believe their first consumer DVD-ROM (100D?? 101A?? .. big SCSI thing) was actually made my them.
Post by Coopervid » Fri Sep 13, 2024 4:26 pm
flojo wrote: Thu Sep 12, 2024 12:44 pm Could you PM the link too? I just picked one up.
Post your Makemkv info.
Post by Coopervid » Sun Sep 15, 2024 9:12 am
sense wrote: Mon Mar 25, 2024 9:26 pm Hello Coopervid,
could you please send me the instructions to downgrade the XS07U to a libredrive firmware ?
dinosaw
Post by dinosaw » Wed Sep 18, 2024 10:40 am
I've got a drive I'd like to flash, or crossflash:
Revision: 1.01
Serial number: ...
Highest AACS version: 76
Coopervid, can you send me the instructions?
Post by Coopervid » Wed Sep 18, 2024 4:09 pm
dinosaw wrote: Wed Sep 18, 2024 10:40 am I've got a drive I'd like to flash, or crossflash:
Revision: 1.01
Serial number: ...
PM sent
dinosaw
Post by dinosaw » Wed Sep 18, 2024 4:11 pm
Thanks! This worked, here is what I see now:
Product: BD-RW BDR-XS07U
Revision: 1.01
Serial number: ...
Drive platform: RS8E21
Firmware version: 1.01/ID69
Can you let me know what are the changes between these firmware versions? Is it just UHD ripping ability?
