Any Blu Ray i try and rip with a linear PCM soundtrack will crash the program straight away
Has anyone else experienced this issue?
I've ripped the Blu ray first with AnyDVD and then mounted the image. LPCM movies are the only ones that just crash the program. I tell it to choose the soundtrack, then click start, and it crashes right away
thanks
Any BD with LPCM crashes
- Contact:
Re: Any BD with LPCM crashes
A similar bug was fixed in 1.6.15 . If 1.6.15 still fails, then please reply here.
Hi Mike,
Working a bit better now, but still crashing on some disks. It will get to around 2GB in size when ripping and then just hang, then the application will say it needs to close.
EDIT - Some more info for you Mike, on some discs it appears to have frozen, but if you keep an eye on the destination folder the file is being created and going up in size, you just can't view the progression in the program window!
thanks
thanks
