Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
lowertadpole0 wrote: Thu Sep 12, 2024 4:17 am Hello, newcomer here, tried to rip my first UHD movie, ran into what looks to be the same firmware as many have posted above, possible to get some firmware help as well? Thank you.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 50
Drive platform: RS8511
Firmware version: 1.14
PM sent.
sifubigdaddycool wrote: Thu Sep 12, 2024 8:27 pm Also looking to rip UHD
Current profile: DVD-ROM
Revision: 1.14
Any assistance would be greatly appreciated!
PM is coming.
lowertadpole0
Post by lowertadpole0 »
Coopervid wrote: Sun Sep 15, 2024 10:48 am
OS device name: E:
Revision: 1.14
PM sent.
Thank you! That worked for me.
sifubigdaddycool
Post by sifubigdaddycool »
Coopervid wrote: Sun Sep 15, 2024 10:49 am
Revision: 1.14
PM is coming.
EZPZ, thanks!
edwasa wrote: Sun Sep 15, 2024 4:20 am Hi Coopervid. I'm jumping on the train. It would be great if I can use the drive below to read UHD discs. Appreciate your work.
Revision: 1.14
Serial number: xxx
Highest AACS version: 77
PM sent.
PixelBits wrote: Sun Sep 15, 2024 9:56 am Hi all,
I found this website/forum doing some googling about my USB Pioneer BD-RW Drive.
I have a Pioneer BD-RW BDR-UD03D [ extra character 'D' in product id ] and cant find that much regarding this particular drive, makeMKV only shows limited info about the hardware. Does anyone know if this is compatible/moddable for UHD media.
OS device name: U:
Product: BD-RW BDR-UD03D
Revision: 1.00
Highest AACS version: 14
many thanks in advance. 8)
PM sent. Read carefully and do it step by step.
edwasa
Post by edwasa »
Coopervid wrote: Tue Sep 17, 2024 3:34 pm
Revision: 1.14
Serial number: xxx
PM sent.
You're a legend, worked perfectly. Thanks Coopervid.
startrader
Post by startrader »
Hi Coopervid,
can i become the Info for flash pls...
Laufwerksinformation
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.05
Serienummer:
Firmware-Datum: 2015-11-24
Highest AACS version: 68
Drive platform: RS8510
Firmware version: 1.05
thx
startrader wrote: Tue Sep 17, 2024 8:05 pm Hi Coopervid,
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.05
Serienummer:
thx
PM sent.
startrader
Coopervid wrote: Wed Sep 18, 2024 4:13 pm
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.05
Serienummer:
thx
PM sent.
Thanks, unfortunately the tool doesn't recognize the drive... it's a Verbatim BIAA 43891. Is that the reason? or what could be the reason? Started the tool as admin and tried other ports too.
startrader wrote: Wed Sep 18, 2024 8:03 pm
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.05
Serienummer:
thx
PM sent.
Did you follow the tutorial????
Coopervid wrote: Wed Sep 18, 2024 9:28 pm
PM sent.
Did you follow the tutorial???? If so, the enclosure chip is the problem.
startrader
Coopervid wrote: Wed Sep 18, 2024 9:29 pm
I solved the problem by using a Win 10 PC. The drive was then immediately recognized in the flash tool and now it can also read UHD disks! Thank you!
chriskiller
Post by chriskiller »
Is it possible to flash BDR-UD03FAL to read UHD? I don't physically have the drive so I cant post MKV info.
chriskiller wrote: Thu Sep 19, 2024 1:55 am Is it possible to flash BDR-UD03FAL to read UHD? I don't physically have the drive so I cant post MKV info.
So. How should I know. It is likely but get the drive and post the Makemkv info.
