ripped episodes in wrong order/question
DarthJarJar
#1 Post by DarthJarJar » Fri Sep 06, 2024 9:35 am
This is my first time using makemkv. I ripped the superman complete animated series . The episodes were in the wrong order. Is this typical with bluerays? Had to manually make sure the episodes were in the right order.
Re: ripped episodes in wrong order/question
#2 Post by Woodstock » Fri Sep 06, 2024 1:29 pm
Typically, MakeMKV rips things in the order they are in in the directory of the disk. This is NOT necessarily "File name order", but the way the disk is laid out. I have had a number of disks from certain manufacturers that had weird directories.
If a disk has the directory track with file order of, say, "1, 4, 5, 6, 2, 3, 7" physically, a standard directory command will sort them to "1, 2, 3, 4, 5, 6, 7", but that's not the order MakeMKV will rip them.
I've gotten used to this crap, but I also manually tag the file names when ripping anyway.
UnitOne
#3 Post by UnitOne » Fri Sep 06, 2024 3:24 pm
It's routine for series, especially cartoons, to have the order on their home video release not match the air dates.
This is not a technical issue with MakeMKV. Welcome to hell. I had to check every episode of all 28 Rugrats DVDs when I got that set.
DarthJarJar
#4 Post by DarthJarJar » Sat Sep 07, 2024 5:01 am
Thank you guys. I can get used to it, just wanted to make sure it was normal.
darqman
#5 Post by darqman » Mon Sep 16, 2024 10:24 pm
My understanding is that a lot of discs with episodes put them on disc in production order and ordered by aired date. So yeah, must verify each one. A real bummer.
