Opening Verbatim 43888
gck303
Post by gck303 »
I have just received my new Verbatim 43888 drive. It works perfectly and I am able to rip blueray and UHD.
I want to mount this drive internally inside a Dell Optiplex. I assume that inside the Verbatim USB device is a standard SAT drive?
How do I open it?
There are no screws or anything else that seemes like a way in. Just two narrow slits down each side.
Thanks, George
Re: Opening Verbatim 43888
gck303 wrote: Thu Sep 05, 2024 6:32 am I have just received my new Verbatim 43888 drive. It works perfectly and I am able to rip blueray and UHD.
How do I open it?
Thanks, George
Pretty much this will need brute force because the two housings are just connected usings snaps. It will most likely have a slim SATA interface. So you will need a slim SATA to full size SATA adapter and also a special drive bay for the slim drive to fit a 5,25" bay. Pretty expensive and in addition you lose your warranty for the Verbatim drive. I recommend not to do this. Tell me your country of residence and I will suggest to get a full size 5,25" Pioneer drive that still can be made UHD capable.
gck303
Post by gck303 »
I have a SFF optiplex which takes a slimline drive.
So... I am guessing that if I prize it open that it should fit just fine?
gck303 wrote: Sun Sep 08, 2024 7:01 pm I have a SFF optiplex which takes a slimline drive.
I don't like the idea.
1) You will void warranty
2) You still need the slim to full size SATA adapter
Depending on your country you can get a full size flashable Pioneer starting at $80. Instead of spending the money on anythimg else you would have a second drive. Let me / us know and you will get a PM.
senorbluray
Post by senorbluray »
What did you end up doing? Total cost and time invested?
@Coopervid: could you contact me regarding a flashable Pioneer drive? I can't send PMs due to my newbieness.
Thank you :wink:
senorbluray wrote: Mon Sep 16, 2024 12:29 pm What did you end up doing? Total cost and time invested?
Thank you :wink:
What is your country of residence? PM will follow then after info provided.
wblondel
Post by wblondel »
Coopervid wrote: Mon Sep 16, 2024 1:46 pm
Thank you :wink:
Hello, I live in France. May I know where I could get such drives? Thank you!
wblondel wrote: Sat Sep 21, 2024 3:36 pm
Thank you :wink:
Verbatim 43888 on Amazon.fr. Doesn't need to be flashed. Full size Vinpower 212V also on Amazon. Needs to be flashed.
matte_ferrari
Post by matte_ferrari »
could you please explain whai i must do from the start in order to be able to rip 4k Blu-Ray with this drive, thank you.
matte_ferrari wrote: Tue Sep 24, 2024 5:36 pm Hello,
Post your Makemkv info. What do you want or what do you have. I'm not a psycic and can't read minds. You need to give much more information. Posts like yours make me mad. Sorry!
