New LG WH16NS40 won't update
geedub
Post by geedub »
I just got a LG WH16NS40 with a manufacturing date of 2020, which should be fine, based on the list here - viewtopic.php?f=16&t=19634
It came with the 1.04 firmware, but it doesn't seem to be taking the 1.05 firmware I downloaded from this site. It says success after I run the command, but MakeMKV then reports the drive is running 1.04.
Sorry, new to this. I've searched the forum about this drive and can't find much. What part am I missing?
Re: New LG WH16NS40 won't update
Probably enc see guide below
geedub
Post by geedub »
You mean the enclosure? I'm using the Vantec NexStar DX2, which is in the list of approved enclosures for flashing.
geedub wrote: Mon Sep 16, 2024 12:04 am I just got a LG WH16NS40 with a manufacturing date of 2020, which should be fine, based on the list here - viewtopic.php?f=16&t=19634
Use the SDFTool Flasher and flash the drive to WH16NS60 1.02-MK which is the recommended firmware for your model.
