LibreDrive for Pioneer drives
Post by Woodstock » Wed Sep 11, 2024 12:38 pm
Firmware date: 2023-04-20
Pioneer disabled the ability to add UHD ripping to that drive.
Post by Billycar11 » Wed Sep 11, 2024 4:53 pm
MC777 wrote:
Wed Sep 11, 2024 6:37 am
Got my hands on an old ASUS (Pioneer) drive and what I've gathered here is that I might be able to open LibreDrive / UHD on this drive? Any instructions appreciated!
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number: ---
Highest AACS version: 81
Firmware version: ID26
Nah someone updated that one
drknight71
Post by drknight71 » Fri Sep 13, 2024 7:19 pm
Should have but updated firmware from 1.52 to 1.54 on the Pioneer BDR-211M. Before said Libredrive supported and now just possible:
OS device name: E:
Current profile: CD-RW
Manufacturer: PIONEER
Product: BD-RW BDR-211M
Revision: 1.54
Serial number: [redacted]
Firmware date: 2023-02-08
Bus encryption flags: 13
Drive platform: Pioneer RS8800
Firmware version: ID60
What can I do?
Post by Billycar11 » Fri Sep 13, 2024 9:37 pm
OS device name: E:
Revision: 1.54
What can I do?
nothing now sadly its ruined for ripping UHD
drknight71
Post by drknight71 » Fri Sep 13, 2024 11:15 pm
That stinks. Don't own any UHD blurays anyhow. Makemkv still worked though. No way to roll back? Thanks
Chris Kelly
Post by Chris Kelly » Fri Sep 13, 2024 11:24 pm
I made the same fatal mistake with my awesome BDR-212UBK. I feel your pain.
drknight71
Post by drknight71 » Sat Sep 14, 2024 9:54 pm
Tom886 wrote:
Mon Aug 21, 2023 2:17 am
tommik128 wrote:
Wed Aug 09, 2023 2:40 pm
Hi guys, I have the Pioneer 209 EBK (209-M) and the current firmware is only 1.34/ID60. It is probably perfect for MakeMKV but I would like to upgrade the drive since it will be used as a burner as well. Is that 1.54 firmware still safe for MakeMKV? (I guess it might be since that firmware should be quite old - 2020?).
Just registered to reply your question.
The BDR-209EBK is an awesome drive and absolutely makeMKV safe, incl FW1.54.
You can downgrade from v1.54 to previous versions (did it myself) and also crossflash to the BDR-211 v1.53 to read UHD discs (again, done by myself).
One important thing, don't crossflash to v1.54 of the BDR-211, you lose downgrade, crossflash, lose the ability to play UHD with a Leawo Blu-ray player (according to a different forum, other programs may be also affected) and lose the "safety" of makeMKV.
Tom
Tom,
You said you were able to downgrade from 1.54 firmware?? I have a Pioneer BDR-211M that I upgraded from 1.52 to 1.54 and may have lost UHD disk support as I understand from reading these posts. Its not a big deal as I really don't own any UHD disks and can still archive my bluray discs. Was able to run MakeMkv on a bluray without issue but bugs me I lost a perk. So if you wouldn't mind can you detail how you downgraded and where I can find older firmware as I don't have a backup.
Thank you
Post by Coopervid » Sun Sep 15, 2024 10:56 am
Tom
Tom,
Thank you
Sorry but your ruined your drive regarding UHDs and these new firmwares prohibit flashing to older versions.
drknight71
Post by drknight71 » Sun Sep 15, 2024 2:00 pm
Would it be possible to slip the binary firmware file for an older version into the executable updater program to fool it into thinking its flashing a newer firmware and instead downgrade it or is it just not possible due to a hard lock on the firmware itself? As it is right now I should be able to still play UHD disks but just not use MAkeMkv on them? I do also own an LG BH16NS40 thats running older firmware and supports Libredrive mode. Would that be able to read UHD?
Again as far as I am concerned no big deal as most media I consume these days is streamed and all I care about is archiving my old blurays which are all 1080p
Post by Coopervid » Sun Sep 15, 2024 3:53 pm
1) Newer Pioneers are impossible. New firmwares are encrypted.
2) You just need to flash the LG to MK firmware. Read the guide.
drknight71
Post by drknight71 » Sun Sep 15, 2024 4:11 pm
Been reading up and probably have more reading to do. Found something interesting on Doom9 forum. There was a 20 year old thread regarding rolling back old Pioneer DVD drives by simply attaching a '/F' parameter to the flashing program. Found inside the main flash executable two smaller executables 8800BDR-211EBK_UBK_FW152EU.EXE + 8800BDR-211EBK_UBK_KAI_FW152EU.EXE and the bd11_launcher.exe app. So I wonder if you on the command line append a '/F' would it still work..
Just idle curiosity because short of UHD I can still archive my bluray discs as don't own any UHD not in a rush to try.
Post by Coopervid » Sun Sep 15, 2024 4:29 pm
Forget it. Starting December 2022 Pioneer encrypted the firmwares. All firmwares before were not encrypted and yes, you could extract the firmware and the kernel just loading the stock flasher exe in 7zip.
drknight71
Post by drknight71 » Sun Sep 15, 2024 5:01 pm
Ok. Sad.
This doesn't mean that the drive will not work with MakeMkv ... just that Make will have to bypass Libredrive mode through indirect access and there is the risk that some discs will read and others will not because now the firmware can restrict access if I read the technical information correctly? And that maybe one day in the future this will possibly be corrected but just not in the present future?
Thank you.
Post by Coopervid » Sun Sep 15, 2024 8:14 pm
Ok. Sad.
Thank you.
Depending on your country of residence there are reasonably priced alternatives based on Pioneer drives that still can be flashed.
kilolimaalpha
Post by kilolimaalpha » Mon Sep 16, 2024 5:38 pm
Can anyone let me know what I need to do for this so that it can be used for UHD discs? Looks like the firmware is before the encryption, but I still can't read UHD discs. - Thanks!
OS device name: G:
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
