Green Bar and Off Colors
KingStewart
Post by KingStewart » Sun Jan 28, 2024 12:09 pm
When I play some of the Blu-Rays I've ripped there is a Green Bar at the top of the video and the colors appear off.
Attached is an example of this issue.
Is there any way to correct this problem? Thanks
Re: Green Bar and Off Colors
Post by dcoke22 » Tue Jan 30, 2024 12:21 am
Whatever picture you posted didn't seem to make it. But MakeMKV does a pretty good job of copying exactly what's on the disc. It might be something with your playback setup that's giving you troubles.
KingStewart
Post by KingStewart » Wed Sep 04, 2024 2:44 pm
You just have to disable Hard Drive Acceleration in Preferences → Input & Codecs → Codecs and it should solve your problem. 8)
KingStewart
Post by KingStewart » Sun Sep 08, 2024 12:20 pm
Wow! That really worked. Thanks homie.
janegleichner
Post by janegleichner » Sun Sep 15, 2024 4:07 pm
KingStewart wrote: Wed Sep 04, 2024 2:44 pm You just have to disable Hard Drive Acceleration in Preferences → Input & Codecs → Codecs and it should solve your problem. 8)
I fixed it thank you very much
