PM sent.lowertadpole0 wrote: Thu Sep 12, 2024 4:17 am Hello, newcomer here, tried to rip my first UHD movie, ran into what looks to be the same firmware as many have posted above, possible to get some firmware help as well? Thank you.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 50
Drive platform: RS8511
Firmware version: 1.14
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
PM is coming.sifubigdaddycool wrote: Thu Sep 12, 2024 8:27 pm Also looking to rip UHD
Current profile: DVD-ROM
Revision: 1.14
Any assistance would be greatly appreciated!
lowertadpole0
Thank you! That worked for me.Coopervid wrote: Sun Sep 15, 2024 10:48 amPM sent.lowertadpole0 wrote: Thu Sep 12, 2024 4:17 am Hello, newcomer here, tried to rip my first UHD movie, ran into what looks to be the same firmware as many have posted above, possible to get some firmware help as well? Thank you.
OS device name: E:
Revision: 1.14
sifubigdaddycool
EZPZ, thanks!Coopervid wrote: Sun Sep 15, 2024 10:49 amPM is coming.sifubigdaddycool wrote: Thu Sep 12, 2024 8:27 pm Also looking to rip UHD
Revision: 1.14
PM sent.edwasa wrote: Sun Sep 15, 2024 4:20 am Hi Coopervid. I'm jumping on the train. It would be great if I can use the drive below to read UHD discs. Appreciate your work.Code: Select all
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: xxx Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 77 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
PM sent. Read carefully and do it step by step.PixelBits wrote: Sun Sep 15, 2024 9:56 am Hi all,
I found this website/forum doing some googling about my USB Pioneer BD-RW Drive.
I have a Pioneer BD-RW BDR-UD03D [ extra character 'D' in product id ] and cant find that much regarding this particular drive, makeMKV only shows limited info about the hardware. Does anyone know if this is compatible/moddable for UHD media.
OS device name: U:
Product: BD-RW BDR-UD03D
Revision: 1.00
Highest AACS version: 14
many thanks in advance.![]()
edwasa
You're a legend, worked perfectly. Thanks Coopervid.Coopervid wrote: Tue Sep 17, 2024 3:34 pmPM sent.edwasa wrote: Sun Sep 15, 2024 4:20 am Hi Coopervid. I'm jumping on the train. It would be great if I can use the drive below to read UHD discs. Appreciate your work.Code: Select all
startrader
Hi Coopervid,
can i become the Info for flash pls...
Laufwerksinformation
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.05
Serienummer:
Firmware-Datum: 2015-11-24
Highest AACS version: 68
Drive platform: RS8510
Firmware version: 1.05
thx
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.05
Serienummer:
thx
PM sent.startrader wrote: Tue Sep 17, 2024 8:05 pm Hi Coopervid,
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.05
Serienummer:
thx
startrader
Thanks, unfortunately the tool doesn't recognize the drive... it's a Verbatim BIAA 43891. Is that the reason? or what could be the reason? Started the tool as admin and tried other ports too.Coopervid wrote: Wed Sep 18, 2024 4:13 pmPM sent.startrader wrote: Tue Sep 17, 2024 8:05 pm Hi Coopervid,
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.05
Serienummer:
thx
Did you follow the tutorial????startrader wrote: Wed Sep 18, 2024 8:03 pmThanks, unfortunately the tool doesn't recognize the drive... it's a Verbatim BIAA 43891. Is that the reason? or what could be the reason? Started the tool as admin and tried other ports too.Coopervid wrote: Wed Sep 18, 2024 4:13 pmPM sent.startrader wrote: Tue Sep 17, 2024 8:05 pm Hi Coopervid,
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.05
Serienummer:
thx
Coopervid wrote: Wed Sep 18, 2024 9:28 pmDid you follow the tutorial???? If so, the enclosure chip is the problem.startrader wrote: Wed Sep 18, 2024 8:03 pmThanks, unfortunately the tool doesn't recognize the drive... it's a Verbatim BIAA 43891. Is that the reason? or what could be the reason? Started the tool as admin and tried other ports too.
startrader
I solved the problem by using a Win 10 PC. The drive was then immediately recognized in the flash tool and now it can also read UHD disks! Thank you!Coopervid wrote: Wed Sep 18, 2024 9:29 pmCoopervid wrote: Wed Sep 18, 2024 9:28 pmDid you follow the tutorial???? If so, the enclosure chip is the problem.startrader wrote: Wed Sep 18, 2024 8:03 pm
chriskiller
Is it possible to flash BDR-UD03FAL to read UHD? I don't physically have the drive so I cant post MKV info.
So. How should I know. It is likely but get the drive and post the Makemkv info.chriskiller wrote: Thu Sep 19, 2024 1:55 am Is it possible to flash BDR-UD03FAL to read UHD? I don't physically have the drive so I cant post MKV info.
