Optical Drive not "seen"
Cave Wyatt
Post by Cave Wyatt »
i have MakeMKV 1.17.7 and it stopped "seeing" my Pioneer BD drive. I then bought the key, entered it in Register and still no drive. Whatup?
TIA!
Re: Optical Drive not "seen"
Sometimes, if the disk is in the drive before MakeMKV is started, the operating system takes control of it first, and hides its presence from MakeMKV. This can happen more often with USB drives, but it has been known to happen with "fixed" drives.
power off the drive for a min then try again
Cave Wyatt
Woodstock wrote: Sat Sep 14, 2024 12:43 am Sometimes, if the disk is in the drive before MakeMKV is started, the operating system takes control of it first, and hides its presence from MakeMKV. This can happen more often with USB drives, but it has been known to happen with "fixed" drives.
Tried that. Fail!
Cave Wyatt
Billycar11 wrote: Sat Sep 14, 2024 3:57 am power off the drive for a min then try again
Hmm...these are all newer that the pioneer drive I have maybe I'll try one. Thanks!
