DVD loses last half of chapters
ThatGeekEvan
#1 Post by ThatGeekEvan » Fri Sep 13, 2024 11:50 pm
I have a (what I'm presuming is a bootleg) DVD from eBay, it's a TV show, with 23 episodes as one Title with 23 Chapters. When i play the disc with VLC it shows all 23 chapters. But when i open it with MakeMKV i get this:
MakeMKV v1.17.5 win(x64-release) started
Cells 14-23 were removed from title end
Title #1 was added (13 cell(s), 5:17:37)
it chops off the last 1/2 of the disc. What is causing this and what can i do to fix it? I can convert it through VLC but i'm not about to let a disc run for 8+ hours... (there's 19 discs in the set)
Re: DVD loses last half of chapters
#2 Post by dcoke22 » Thu Sep 19, 2024 6:27 pm
Does using any of the various DVD Opening Modes help?
ThatGeekEvan
#3 Post by ThatGeekEvan » Thu Sep 19, 2024 6:46 pm
No. I tried those and it didn't chnage anything
htpc_rookie
#4 Post by htpc_rookie » Fri Sep 20, 2024 11:48 am
Have you tried just copying the disc contents onto your PC? If it does copy and isn't encrypted maybe you will be able to extract meaningful files through other means.
Ezatoka
#5 Post by Ezatoka » Fri Sep 20, 2024 2:23 pm
You should give the Manual Mode a try and see, if selecting track 1 this way gives you all chapters.
