#10321 Post by RESET_9999 » Wed Sep 11, 2024 7:15 pm
I pushed JW2 through the 9-2 workflow and got a single .hevc file. The 4-2 workflow requests two input files, has something gone wrong?
if you rip to a BDMV/ISO, just demux the layers with tsmuxer and change the framerate of each stream with DS.
if you rip to MKV, you have to demux the layers. Workflow 1 and select R (remove) and change the framerate of each stream with DS.
then make a new ST-DL in 4-2
What does the 9-2 do to the biststream DTS-HD track - does that get fixed,
nothing and the point of changing the framerate is to get the TrueHD track so the original 24fps DTS track is now useless.
The link to subtitles is labelled as 23.976. As my UK Atmos release has an extra second of blank-screen time at the start, I guess I'll have to snip that off to preserve subtitle and audio sync,
the subs I linked are for the slowed down Italian bluray so once you change the videos framerate to 23.976, they will fit.
I received the Italian JW1 disc today
subs for the Italian BD JW1:
https://drive.google.com/drive/u/0/fold ... hC2TOamMyS
morbius
#10322 Post by morbius » Wed Sep 11, 2024 9:12 pm
thanks for your patience. I rip to mkv, I successfully demuxed to two hevc files and fixed their framerates and then combined. I now have a ST-DL hevc file. Looking for a work flow to convert this to mkv, I've looked through the options but can't find it?
(I tried the mkv batch muxer but on hitting return after dropping in the file it immediately reports completion without having done anything).
#10323 Post by RESET_9999 » Wed Sep 11, 2024 9:30 pm
you mux the new ST hevc file and audio/subs with mkvtoolnix. No script is required for that.
https://mkvtoolnix.download/downloads.html
morbius
#10324 Post by morbius » Wed Sep 11, 2024 9:39 pm
thanks, I use mkvtoolnix all the time, didn't realise it could read hevc files.
deadchip12
#10325 Post by deadchip12 » Thu Sep 12, 2024 12:31 am
RESET_9999 wrote:
Wed Sep 11, 2024 10:58 am
Also you have to use the P5 webdl and not the P8 version as your picture shows.
Oops I used P8 version with The Marvels...
Why do we need to use P5 instead of P8?
#10326 Post by RESET_9999 » Thu Sep 12, 2024 1:39 am
Because the DV source is the P5 webdl and sometimes the studios decide to deliver a different version for the HDR10 stream. Marvel's Black Widow is one of those IIRC.
ColonelBlimp043
#10327 Post by ColonelBlimp043 » Thu Sep 12, 2024 11:23 am
I am in the process of generating RPUs for some of my UHD HDR10 rips with 3-1. Pardon if this has already been asked before, but is there a recommended procedure for setting the L5 offsets on films with variable aspect ratios (i.e. Nolan IMAX UHD). Should I set the L5 offsets at 0 to accommodate the 1.78:1 IMAX scenes, or is it recommended to use the appropriate widescreen offsets, since those scenes make up the majority of the runtime?
#10328 Post by RESET_9999 » Thu Sep 12, 2024 12:05 pm
yes 0, otherwise if you watch on a device that uses L5 (tv internal player), there will be a letterbox for the Imax shots.
morbius
#10329 Post by morbius » Thu Sep 12, 2024 7:23 pm
RESET_9999 wrote:
Mon Sep 09, 2024 6:53 pm
I'm using the values provided by MediaInfo, is that correct?
yes
One point in this workflow that does not have an automatic option is the prompt for the Mastering Display choice
it's because I prefer selecting MDL based on the content's actual brightness.
So, after what proved to be an educational journey, I now have John Wick 2 in DV7 FEL with TrueHD audio and the forced subs. When doing the final mux I set a delay of 1001ms on the video and the forced subs, and I have perfect audio sync with the video. The result is well worth the effort! JW1 will be much easier.
In the quote above, I asked about the 3-1 workflow for converting HDR10. Can you expand on selecting MDL based on content actual brightness? I guess there is a workflow for identifying the content brightness, and based on that I pick from one of the fixed 1000/2000/4000 options?
morbius
#10330 Post by morbius » Thu Sep 12, 2024 8:25 pm
thanks for the link. The JW1 subs are extremely dark. I tried to fix that using the 9-5 workflow with the .bat file changed to set the brightness adjustment to 150%, but it didn't help. Any other method for fxing that?
#10331 Post by RESET_9999 » Thu Sep 12, 2024 10:03 pm
I don't know, convert to SRT.
https://github.com/SubtitleEdit/subtitleedit
I measure brightness with 6-2 and select MDL accordingly.
deadchip12
#10332 Post by deadchip12 » Thu Sep 12, 2024 11:31 pm
Ok so we need to use P5 webdl to transfer DV to HDR10 bluray.
If the bluray already has DV and we just want to transfer cmv4.0 bloc to bluray, can we use P8 webdl or do we have to use P5 as well? Quite hard to find P5 webdl online.
#10333 Post by RESET_9999 » Fri Sep 13, 2024 12:14 am
what matters is the metadata only. hdr10 brightness doesn't matter
deadchip12
#10334 Post by deadchip12 » Fri Sep 13, 2024 12:56 am
In case I can't find the P5 webdl online to do the DV tranfer to HDR10 bluray, can I use the .bin files in your RPU folder? I just checked one and they were P8, not P5?
#10335 Post by RESET_9999 » Fri Sep 13, 2024 1:31 am
yes, my RPUs are P8 synced and ready to be injected.
