dchop
Post
by dchop » Mon Sep 02, 2024 10:57 pm
When I try to load the software I get the fatal error message. It says the program is closing but the software opens but pretty much can do nothing. I've rebooted the system and I've tried loading it without the disc drive connected. Same error and behavior.
I just purchased the license and did an uninstall, downloaded the latest version but get this error. The event log error is below. It's a Windows 10 Enterprise 64bit system.
- System
- Provider
[ Name] Application Error
- EventID 1000
[ Qualifiers] 0
Version 0
Level 2
Task 100
Opcode 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2024-09-02T22:43:02.8234431Z
EventRecordID 2136975
Correlation
- Execution
[ ProcessID] 0
[ ThreadID] 0
Channel Application
Computer *****I've removed this info*****
Security
- EventData
makemkvcon64.exe
1.17.7.0
66436876
unknown
0.0.0.0
00000000
c0000005
00000213ca6d1340
2bd4
01dafd8977ec50bc
C:\Program Files (x86)\MakeMKV\makemkvcon64.exe
unknown
3c600cc5-aa98-4482-8368-9e7990caf612
mwarmann
Post
by mwarmann » Tue Sep 10, 2024 2:44 am
ditto I am experiencing the exact same thing. Had used the program for several months. My beta license key expired. Tried resetting the pc clock, and ripping a bluray and was told the pc system clock was wrong. So removed Makemkv, reloaded sw, after updating clock/calendar to correct date/time and setting to auto update. Reloaded Makemkv sw and got "fatal error message. So decided to own up, purchased the $60 license. rebooted several times and whenever I load MAke Mkv I get the fatal error msg. Cant even get to the screen to load my permanent license.
Any thoughts?
joj5541
Post
by joj5541 » Tue Sep 10, 2024 4:42 am
Same here, except before the fatal error message, I get a dialog:
MakeMKV BETA popup:
This application version is too old. Please download the latest version at
http://www.makemkv.com/ or enter a registration key to continue using the current version.
I also purchased a registration key in hopes that it would resolve it, but no joy.
Parrothead
Post
by Parrothead » Tue Sep 10, 2024 11:24 am
Same situation here. I wish I could help but I came here hoping to find an answer.
Parrothead
Post
by Parrothead » Tue Sep 10, 2024 1:59 pm
Parrothead wrote: Tue Sep 10, 2024 11:24 am
Update: I am running Windows 11 with no internal DVD drive. Unplugged the external DVD drive, started up MakeMKV, was able to register the permanent key and it seems to be working now.
usethis
Post
by usethis » Tue Sep 10, 2024 3:32 pm
Parrothead wrote: Tue Sep 10, 2024 1:59 pm
Cheers mate, same here with an external Drive on MacOS. Unplugged, started the app successfully, registered the new key, app closed normally, hooked up the drive and started the app again. All seems ok now.
Parrothead
Post
by Parrothead » Tue Sep 10, 2024 4:15 pm
usethis wrote: Tue Sep 10, 2024 3:32 pm
Glad my stroke of luck helped!
mwarmann
Post
by mwarmann » Tue Sep 10, 2024 6:02 pm
Usethis thank you! That worked. First I unplugged the external USB blue ray and dvd players. Then I removed the application from my Win10 machine. Reloaded it for the web site. At first got the same outdated version pop up. But I clicked on register which was available. I copy/pasted the license key in and said ok. The app took it and told me to close and re-open the app. I closed the app, rebooted my pc and it works now.
Yea! And the I you.
Mark
drvcycle
Post
by drvcycle » Tue Sep 10, 2024 11:18 pm
I have verified that this process also works with internal DVD drives on a Linux system.
This is what I did to get MakeMKV working again:
1. Found the updated license key and saved it to a text file
2. Shutdown the system
3. Opened computer and pulled the power cable from the DVD drive
4. Booted system
5. Started MakeMKV and pasted the new key in the registration dialog box
6. Shutdown the system again
7. Plugged the power cable back into the DVD drive
8. Booted system and closed the case
9. MakeMKV now works! No more crashing!
Hopefully this problem gets fixed in the next version!
dchop
Post
by dchop » Wed Sep 11, 2024 1:26 am
I've tried all combinations of everything that has been suggested. Still no luck. Will continue searching for answers.
joj5541
Post
by joj5541 » Wed Sep 11, 2024 11:18 pm
joj5541 wrote: Tue Sep 10, 2024 4:42 am
MakeMKV BETA popup:
As others have reported, removing the the optical drive temporarily, then registering the key, then reattaching the optical drive got things working. The issue was occurring on both Mac and PC. I've only confirmed the fix on the Mac.
