The Incredible Hulk SCSI Error
MVLPGaming
#1 Post by MVLPGaming » Wed Sep 11, 2024 8:27 am
Hello together, i have an issue with the BluRay
The Incredible Hulk from 2008
when I try to open the BluRay I get the following error on the Debug Log
Debug log started at Wed Sep 11 08:18:01 2024 , written by MakeMKV v1.17.7 win(x64-release)
001005:0000 MakeMKV v1.17.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Administrator/MakeMKV_log.txt
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command 460200010..00100 to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 0 at :_D~hKrDX!l7kzzP:121271778
001003:0020 DEBUG: Code 0 at :_D~hKrDX!l7kzzP:213137367
001003:0020 DEBUG: Code 0 at :_D~hKrDX!l7kzzP:29400807
No  SDF v098: QEMU_QEMU_DVD-ROM_2.5+
DEBUG: Code 3 at wsuH-I{pjx"D{a*<>oxG0$',:29395310
SDF id v098: QEMU_QEMU_DVD-ROM_2.5+
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command 460200010..00100 to device 'SPTI:\Device\CdRom1'
SDF  v098: PIONEER_BD-RW___BDR-UD04_1.14_ACDL066654WL
001003:0020 DEBUG: Code 100864261 at :_D~hKrDX!l7kzzP:121271617
001003:0020 DEBUG: Code 100864261 at y/G?z@b0R+~Y]$0V:213130559
001003:0020 DEBUG: Code 100864261 at 8)gN3IM7_1@BG-`Ird:121263429
001003:0020 DEBUG: Code 100864261 at 8)gN3IM7_1@BG-`Ird:121262302
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW   BDR-UD04 1.14 ACDL066654WL' at offset '65536'
001012:0000 udf: UDF mount: reading in reserve VDS extent
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW   BDR-UD04 1.14 ACDL066654WL' at offset '1310720'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW   BDR-UD04 1.14 ACDL066654WL' at offset '1366016'
001012:0000 udf: 	node fe/efe failed!
001003:0020 DEBUG: Code 117506188 at 8)gN3IM7_1@BG-`Ird:121263429
001003:0020 DEBUG: Code 117506188 at 8)gN3IM7_1@BG-`Ird:121262302
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-RE PIONEER BD-RW   BDR-UD04 1.14 ACDL066654WL' at offset '1310720'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-RE PIONEER BD-RW   BDR-UD04 1.14 ACDL066654WL' at offset '1366016'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-RE PIONEER BD-RW   BDR-UD04 1.14 ACDL066654WL' at offset '1114112'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-RE PIONEER BD-RW   BDR-UD04 1.14 ACDL066654WL' at offset '720896'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-RE PIONEER BD-RW   BDR-UD04 1.14 ACDL066654WL' at offset '765952'
001003:0020 DEBUG: Code 0 at 0:06-X[o+]z.qq7'J:213130283
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-RE PIONEER BD-RW   BDR-UD04 1.14 ACDL066654WL' at offset '983040'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-RE PIONEER BD-RW   BDR-UD04 1.14 ACDL066654WL' at offset '1021952'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-RE PIONEER BD-RW   BDR-UD04 1.14 ACDL066654WL' at offset '1030144'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-RE PIONEER BD-RW   BDR-UD04 1.14 ACDL066654WL' at offset '851968'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-RE PIONEER BD-RW   BDR-UD04 1.14 ACDL066654WL' at offset '876544'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-RE PIONEER BD-RW   BDR-UD04 1.14 ACDL066654WL' at offset '1003520'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-RE PIONEER BD-RW   BDR-UD04 1.14 ACDL066654WL' at offset '1345536'
Application exited at Wed Sep 11 08:20:31 2024
The Disc is cleaned several time and also the laser lens.
Some how Make MKV get the Information's from the BluRay but can't access the Video data.
OS device name: \Device\CdRom2
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Drive platform: RS8A10
Firmware version: 1.14
Disc Information
Label: DER UNGLAUBLICHE HULK
Timestamp: 2008-10-21 07:19:41
Data capacity: 45.78 Gb
Disc type: BD-ROM
Number of layers: 2
Does anyone had the same issue?
Re: The Incredible Hulk SCSI Error
#2 Post by dcoke22 » Sat Sep 21, 2024 12:51 pm
It looks like the drive encounters a few spots on the disc that it can't read. You might need to replace the disc.
