Download MakeMKV 1.17.7 fatal error
slayerbla1974
Post by slayerbla1974 »
when the new beta password for october 1.17.7 installed freezes then i get fatal error occurred program will now close, and other times it asks for password
then freeze worked last month windows 11
Re: Download MakeMKV 1.17.7 fatal error
Was your optical drive empty when you started the program, so that you could enter the new key? Turns out there is an issue with saving the key when the drive has something in it... I just updated the FAQ about that.
slayerbla1974
nope still freezes
slayerbla1974
also i installed it on win 10 no problems
Binky Huckaback
Post by Binky Huckaback »
I have an M1 Mac Mini running Sonoma 14.6.1 and have installed the latest version of MakeMKV Beta and I'm getting the same error message - Fatal error occored, program will now exit.'
andreaOL
Post by andreaOL »
Try this site and its key
https://www.makemkv.com/buy/
slayerbla1974
i also installed makemkv on my win 10 works fine on there
