Issue with "A Quiet Place"
Appfel
Post by Appfel »
Hello!
Hopefully you can help me. I have issues with "A Quiet Place". The disk is transparent. Maybe the transparancy is the issue?
I receive the following log.
1 Titel werden in Verzeichnis /Volumes/Intenso 5TB/BluRay/A Quiet Place gespeichert
Fehler 'SCSI-Fehler - ILLEGAL REQUEST:INVALID FIELD IN CDB' trat auf während des Auslesens von '/BDMV/STREAM/00800.m2ts' bei Offset '21863989248'
Fehler 'Posix-Fehler - Input/output error' trat auf während des Auslesens von '/dev/rdisk8' bei Offset '21863989248'
Titel 0 in Datei /Volumes/Intenso 5TB/BluRay/A Quiet Place/A Quiet Place_t00.mkv zu speichern schlug fehl
0 Titel wurden gesichert, 1 schlugen fehl
My client is German so the log is German. So here is a translation done with a tool:
1 title is being saved in directory /Volumes/Intenso 5TB/BluRay/A Quiet Place
Error 'SCSI error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '21863989248'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk8' at offset '21863989248'
Saving title 0 to file /Volumes/Intenso 5TB/BluRay/A Quiet Place/A Quiet Place_t00.mkv failed
0 titles were saved, 1 failed
This is the latest log. Before I had a different error message, stating Read Error. I understand that this sounds like a read error which is linked to either the drive (I use techPulse120, I had no issues with other disks, but have issues with both HD and UHD disks of "A Quiet Place". I tried with 1 UHD and 2 HD disks. All three not working. The log above is from an HD only BluRay. Cleaning the disk with some water spray and a microfibre cloth was not helpful.
Is there something I could try?
Thanks so much in advance. This is my first post, so please feel free to friendly tell me if I made a mistake or something. I searched the forum but was unable to find a post reflecting my issue quit good.
Re: Issue with "A Quiet Place"
A number of possibilities. Damaged or dirty disk at that offset is possible; cleaning it often helps.
Another possibility is that the disk drive shuts down when it goes too fast. The offset will usually change with different runs, but you'll usually hear the disk spin down just before the errors start appearing. This happens mostly with external drives, powered by USB. Most drives require TWO power hookups for standard USB 2.0, and they have to be from ports with different power sources. A separate, powered, USB hub often fixes that.
Appfel
Post by Appfel »
Hello Woodstock!
Thanks for your answer. I tried once more cleaning the disk and got an external powered USB Hub. Unfortunately it was not really helpful in solving the issue. But I now tried to just copy the disk content and it is the same: it seems to be fine till approximately 90% and then it just runs in any error…
