Which drive did you get? I will follow up but right now I‘m on vacation. Expect some delay.
Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Okona
I got the Vinpower Digital BDR-212V you recommended.Coopervid wrote: Tue Sep 10, 2024 8:17 pm Which drive did you get? I will follow up but right now I‘m on vacation. Expect some delay.
I wish you a happy vacation.
ElektroMorph
Looking at buying that Vinpower Digital BDR-212V drive from Amazon, will I need to flash it or will it work without flashing
needs to be flashed for UHDElektroMorph wrote: Thu Sep 12, 2024 8:16 pm Looking at buying that Vinpower Digital BDR-212V drive from Amazon, will I need to flash it or will it work without flashing
chanceForn
Country of Residence: US
Preference: 5.25" drive internal
Looking for the current best drive for UHD and LibreDrive, and in general fullest functionality for MakeMKV.
Was originally considering https://www.amazon.com/Pioneer-BDR-212V ... B08R89FN61 but concerned that it may have the encrypted firmware.
Thanks in advance!
Thanks in advance!
Buy it. It can be flashed.chanceForn wrote: Wed Sep 18, 2024 6:10 am Hello,
Thanks in advance!
chanceForn
Thank you for the quick reply, I've bought it!Coopervid wrote: Wed Sep 18, 2024 2:49 pmBuy it. It can be flashed.chanceForn wrote: Wed Sep 18, 2024 6:10 am Hello,
Thanks in advance!
Read your PM.chanceForn wrote: Wed Sep 18, 2024 3:32 pmThank you for the quick reply, I've bought it!Coopervid wrote: Wed Sep 18, 2024 2:49 pmBuy it. It can be flashed.chanceForn wrote: Wed Sep 18, 2024 6:10 am Hello,
Thanks in advance!
chanceForn
Thank you!Coopervid wrote: Wed Sep 18, 2024 4:50 pmRead your PM.
EDIT: I'm not fan of Amazon, but I bought this morning and this afternoon they delivered it. Worked perfect!
As Stock:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: -snip-
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 38
Firmware version: ID06Code: Select all
Product: BD-RW BDR-S12U
Revision: 1.02
Firmware date: 2022-03-07
Drive platform: RS8F01
Firmware version: 1.02/ID43
bootcheck
Could you please recommend drive?
Media: Bluray, UHD 4K
Format: 5.25" internal bay
Country: Poland
Country: Poland
Try to get the Vinpower 212V. Maybe from Amazon.de. I didn‘t find it in Poland.bootcheck wrote: Thu Sep 19, 2024 12:19 pm Could you please recommend drive?
Country: Poland
bootcheck
Found it on AMZN.de, but they won't ship to PL.
Any alternatives?
Would it handle UHD?
newmkmkv
I'd also like to have a recommendation. Internal or external does not matter.
It should work with Blu-Ray, UHD, DVD but also do good audio rips with EAC or dbPowerAMP etc.
Country: Germany
Also any pointer to what I need to do wrt firmware for the recommended drive would be appreciated!
thanks!
Country: Germany
thanks!
Internal: Vinpower 212Vnewmkmkv wrote: Thu Sep 19, 2024 6:20 pm Hi,
Country: Germany
thanks!
External: Verbatim 43888
