Beta Key Expired
satya
Beta Key Expired
#1 Post by satya » Sun Sep 01, 2024 1:55 am
old beta key is expired, please update new key for september, thank you.
Re: Beta Key Expired
#2 Post by Woodstock » Sun Sep 01, 2024 3:06 am
If you search for "beta expired" here, you will find a lot of messages, all dated every two months. All mentioning that you have to wait for the program's author to create a new one, and how it often happens that it takes a day (or several) for that to happen. There are also suggestions of how to get around that, if you aren't inclined to buy your own key, yet.
satya
#3 Post by satya » Sun Sep 08, 2024 3:47 am
Still Waiting for the new beta key, please update it, thanks in advance.
bmillham
#4 Post by bmillham » Sun Sep 08, 2024 8:41 pm
If it bothers you that much and you use MakeMKV that much then why not support the author and purchase a key???
eloisefreya
#5 Post by eloisefreya » Sun Sep 08, 2024 9:04 pm
I’m not sure if I’m allowed to say this… but if you reset your computer clock before starting MakeMKV it works with the August 2024 code.
satya
#6 Post by satya » Mon Sep 09, 2024 1:46 am
right now i dont have more money, but definitely in future i will buy it.
bagman
#7 Post by bagman » Mon Sep 09, 2024 11:26 am
This is almost $100 in Australia. If only it were a little cheaper I would get it today. Does anyone know if there are specials (new to all this)?
Thanks in advance
satya
#8 Post by satya » Tue Sep 10, 2024 2:16 pm
Thanks for the new key
