I've using this drive for a few years now to rip UHD discs and the other day it broke on me for whatever reason. I bought a new one but now I need to flash it and I can't remember how I did it last time but it was as simple as copying and pasting a command into the control center on a PC. I bought a little PC so I can do the same thing but I can't seem to find the right commands to plug in to get it flashed. Can anyone help me out? I'm not smart enough for this stuff and I just want to get back to ripping my favorite UHD movies as they come out
archgon Ultra Slim Portable Drive (Model: MD-8107-U3)
Hey guys,
Re: archgon Ultra Slim Portable Drive (Model: MD-8107-U3)
To add, I normally use a mac so if there's anyway to do it on a mac, even better.
See guide below
Having trouble with the "all you need" firmware pack. I'm not seeing anything specific to the archgon. Is there one that works universally for all drives of this type?
It's a bu40n look at the drive info
On the mac/linux steps, step number 4 is where I'm getting stuck. How do I copy the sdf.bin and the other drive info into the /tmp folder in the terminal?
It doesn't really matter where you store those files as long as you properly reference them on the command line. '/tmp' is a common unix reference for 'a temporary place'.nkley wrote: Wed Sep 11, 2024 2:56 am On the mac/linux steps, step number 4 is where I'm getting stuck. How do I copy the sdf.bin and the other drive info into the /tmp folder in the terminal?
On the Mac, if you stored them in a folder on your desktop, you can drag the file into Terminal and the fully qualified path to that file will appear. Using this trick, you can 'build' the necessary command line for your specific system and file locations.
Drag items into a Terminal window on Mac
Terminal User Guide
can this drive burn DVD+R DL discs? cuz i have been unsuccessful so far.
This probably isn't the forum to ask about burning discs. Most of the discussion here is about reading discs, not burning them.neo305 wrote: Thu Jan 08, 2026 9:08 pm can this drive burn DVD+R DL discs? cuz i have been unsuccessful so far.
Out of curiosity, why are you trying to burn a disc?
I am trying to make a backup of my original. I'm using dvdfab and failed 5 times already
