Beta Key Expired
satya
Beta Key Expired
Post by satya »
old beta key is expired, please update new key for september, thank you.
Re: Beta Key Expired
If you search for "beta expired" here, you will find a lot of messages, all dated every two months. All mentioning that you have to wait for the program's author to create a new one, and how it often happens that it takes a day (or several) for that to happen. There are also suggestions of how to get around that, if you aren't inclined to buy your own key, yet.
satya
Post by satya »
Still Waiting for the new beta key, please update it, thanks in advance.
bmillham
Post by bmillham »
If it bothers you that much and you use MakeMKV that much then why not support the author and purchase a key???
eloisefreya
Post by eloisefreya »
I’m not sure if I’m allowed to say this… but if you reset your computer clock before starting MakeMKV it works with the August 2024 code.
satya
Post by satya »
bmillham wrote: Sun Sep 08, 2024 8:41 pm If it bothers you that much and you use MakeMKV that much then why not support the author and purchase a key???
right now i dont have more money, but definitely in future i will buy it.
bagman
Post by bagman »
eloisefreya wrote: Sun Sep 08, 2024 9:04 pm I’m not sure if I’m allowed to say this… but if you reset your computer clock before starting MakeMKV it works with the August 2024 code.
This is almost $100 in Australia. If only it were a little cheaper I would get it today. Does anyone know if there are specials (new to all this)?
Thanks in advance
satya
Post by satya »
Thanks for the new key
