LG BP50NB40
rifth427
Re: LG BP50NB40
#16 Post by rifth427 » Sat Sep 07, 2024 5:36 pm
Billycar11 wrote: Wed May 11, 2022 12:10 am look at your svc on the bottom if its nb52 do the nb52 steps
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty
link in guide
Hey, I have a quick question, I followed the guide but I did not see anything about the sec tag being nb52 to do those steps. I did the steps anyway... got an error but 4ks and blur ays rip fine. DVDs spin outta control though.
oh and btw my tag says nb50
What should I do in such a case? Sorry to bother you.
Re: LG BP50NB40
#17 Post by Billycar11 » Sat Sep 07, 2024 6:39 pm
rifth427 wrote: Sat Sep 07, 2024 5:36 pm
Nothing to do really sometime some chips sets makemkv reports an error when flashing but it's fine.
Not sure about the DVD thing should be fine these drives are just loud
Make sure you put the disc in first then let the is see it them open makemkv that avoids alot of issues
rifth427
Re: LG BP50NB40
#18 Post by rifth427 » Sat Sep 07, 2024 8:36 pm
Well, if I didn't hold it down I would swear the burner would fly off the desk. I have to use another drive for DVDs cause literally, it spins so fast it moves the drive and sounds like a jackhammer.
Re: LG BP50NB40
#19 Post by dcoke22 » Sat Sep 07, 2024 8:57 pm
rifth427 wrote: Sat Sep 07, 2024 8:36 pm Well, if I didn't hold it down I would swear the burner would fly off the desk. I have to use another drive for DVDs cause literally, it spins so fast it moves the drive and sounds like a jackhammer.
Perhaps the disc is unbalanced?
You could perhaps also make use of MakeMKV's speed control to slow down DVDs.
flojo
Re: LG BP50NB40
#20 Post by flojo » Tue Sep 10, 2024 9:49 pm
Where is the 1.00? I see the 1.03MK, eg. "HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin", which is in the "The all you need firmware pack.zip" file. Or, is the "DE_LG_BP60NB10_1.00_MK_HBD.bin" inside the "Hybrid_Firmware_for_BP50NB40_to_BP60NB10.zip" the 1.00MK?
Just to be clear, if I have a "NB50", I'm going to effectively do these 2 lines only...
# don't forget the sdf.bin
cp $HOME/Downloads/sdf.bin $PWD
# now flash
./makemkvcon f -d '/My/Device' -f $PWD/sdf.bin rawflash main -i $PWD/HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin
If I wind up with a NB52 SVC Code, I guess I have to use that Windows thing... ...?
