Pioneer BDR-UD03 UHD possibility
Packrat
Re: Pioneer BDR-UD03 UHD possibility
yippee thank you it worked
ronaldgk
Works, thank youCoopervid wrote: Thu Sep 05, 2024 9:29 amPM sent.ronaldgk wrote: Wed Sep 04, 2024 10:21 pmI also have this drive, I will check my PMs
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: [REDACTED] Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 78 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
justabear
Like many others I believe I have the same drive and am curious if there is a way to have it read UHD discs.
Revision: 1.14
Highest AACS version: 75
Sure. Read your PM.justabear wrote: Fri Sep 06, 2024 7:07 pm Like many others I believe I have the same drive and am curious if there is a way to have it read UHD discs.
Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 75 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
justabear
Thank you.Coopervid wrote: Fri Sep 06, 2024 10:47 pmSure. Read your PM.justabear wrote: Fri Sep 06, 2024 7:07 pm Like many others I believe I have the same drive and am curious if there is a way to have it read UHD discs.
ootnes2
Hi I am also curious if there is a way to have the drive read UHD discs, I promise to check my PM!
Revision: 1.00
Serial number: [leaving this out]
Firmware date: 2013-08-09
Highest AACS version: 57
Drive platform: RS8510
Firmware version: 1.00/ID19
Revision: 1.00
ScallyCap
Hello Coopervid hoping you can help with my BDR-UD03 and being able to read UHD
Thank you in advance.
OS device name: E:
Revision: 1.14
Serial number: [redacted]
Highest AACS version: 76
OS device name: E:
Revision: 1.14
PM is coming.ootnes2 wrote: Sat Sep 07, 2024 4:12 pm Hi I am also curious if there is a way to have the drive read UHD discs, I promise to check my PM!
Revision: 1.00
Read your PM.ScallyCap wrote: Sun Sep 08, 2024 3:23 am Hello Coopervid hoping you can help with my BDR-UD03 and being able to read UHD
OS device name: E:
Revision: 1.14
ootnes2
Thanks!!Coopervid wrote: Sun Sep 08, 2024 9:19 amPM is coming.ootnes2 wrote: Sat Sep 07, 2024 4:12 pm Hi I am also curious if there is a way to have the drive read UHD discs, I promise to check my PM!
Revision: 1.00
ScallyCap
Coopervid wrote: Sun Sep 08, 2024 9:26 amRead your PM.ScallyCap wrote: Sun Sep 08, 2024 3:23 am Hello Coopervid hoping you can help with my BDR-UD03 and being able to read UHD
OS device name: E:
Revision: 1.14
Thank you!
lowertadpole0
Hello, newcomer here, tried to rip my first UHD movie, ran into what looks to be the same firmware as many have posted above, possible to get some firmware help as well? Thank you.
OS device name: E:
Revision: 1.14
Highest AACS version: 50
OS device name: E:
Revision: 1.14
sifubigdaddycool
Also looking to rip UHD
Current profile: DVD-ROM
Revision: 1.14
Any assistance would be greatly appreciated!
Revision: 1.14
edwasa
Hi Coopervid. I'm jumping on the train. It would be great if I can use the drive below to read UHD discs. Appreciate your work.
Revision: 1.14
Serial number: xxx
Highest AACS version: 77
PixelBits
Hi all,
I found this website/forum doing some googling about my USB Pioneer BD-RW Drive.
I have a Pioneer BD-RW BDR-UD03D [ extra character 'D' in product id ] and cant find that much regarding this particular drive, makeMKV only shows limited info about the hardware. Does anyone know if this is compatible/moddable for UHD media.
OS device name: U:
Product: BD-RW BDR-UD03D
Revision: 1.00
Highest AACS version: 14
many thanks in advance.
OS device name: U:
Revision: 1.00
