Pioneer BDR-UD03 UHD possibility
Packrat
Re: Pioneer BDR-UD03 UHD possibility
Post by Packrat »
yippee thank you it worked :D
ronaldgk
Post by ronaldgk »
Coopervid wrote: Thu Sep 05, 2024 9:29 am
ronaldgk wrote: Wed Sep 04, 2024 10:21 pm
Coopervid wrote: Sun Sep 01, 2024 6:54 pm
PM sent.
I also have this drive, I will check my PMs
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [REDACTED]
Firmware date: 2020-06-15
Highest AACS version: 78
Drive platform: RS8511
Firmware version: 1.14
PM sent.
Works, thank you :)
justabear
Post by justabear »
Like many others I believe I have the same drive and am curious if there is a way to have it read UHD discs.
Revision: 1.14
Highest AACS version: 75
justabear wrote: Fri Sep 06, 2024 7:07 pm Like many others I believe I have the same drive and am curious if there is a way to have it read UHD discs.
Revision: 1.14
Sure. Read your PM.
justabear
Post by justabear »
Coopervid wrote: Fri Sep 06, 2024 10:47 pm
Revision: 1.14
Sure. Read your PM.
Thank you.
ootnes2
Post by ootnes2 »
Hi I am also curious if there is a way to have the drive read UHD discs, I promise to check my PM!
Revision: 1.00
Serial number: [leaving this out]
Firmware date: 2013-08-09
Highest AACS version: 57
Drive platform: RS8510
Firmware version: 1.00/ID19
ScallyCap
Post by ScallyCap »
Hello Coopervid hoping you can help with my BDR-UD03 and being able to read UHD
Thank you in advance.
OS device name: E:
Revision: 1.14
Serial number: [redacted]
Highest AACS version: 76
ootnes2 wrote: Sat Sep 07, 2024 4:12 pm Hi I am also curious if there is a way to have the drive read UHD discs, I promise to check my PM!
Revision: 1.00
PM is coming.
ScallyCap wrote: Sun Sep 08, 2024 3:23 am Hello Coopervid hoping you can help with my BDR-UD03 and being able to read UHD
OS device name: E:
Revision: 1.14
Read your PM.
ootnes2
Post by ootnes2 »
Coopervid wrote: Sun Sep 08, 2024 9:19 am
Revision: 1.00
PM is coming.
Thanks!!
ScallyCap
Post by ScallyCap »
Coopervid wrote: Sun Sep 08, 2024 9:26 am
OS device name: E:
Revision: 1.14
Read your PM.
Thank you!
lowertadpole0
Post by lowertadpole0 »
Hello, newcomer here, tried to rip my first UHD movie, ran into what looks to be the same firmware as many have posted above, possible to get some firmware help as well? Thank you.
OS device name: E:
Revision: 1.14
Highest AACS version: 50
sifubigdaddycool
Post by sifubigdaddycool »
Also looking to rip UHD
Current profile: DVD-ROM
Revision: 1.14
Any assistance would be greatly appreciated!
edwasa
Post by edwasa »
Hi Coopervid. I'm jumping on the train. It would be great if I can use the drive below to read UHD discs. Appreciate your work.
Revision: 1.14
Serial number: xxx
Highest AACS version: 77
PixelBits
Post by PixelBits »
Hi all,
I found this website/forum doing some googling about my USB Pioneer BD-RW Drive.
I have a Pioneer BD-RW BDR-UD03D [ extra character 'D' in product id ] and cant find that much regarding this particular drive, makeMKV only shows limited info about the hardware. Does anyone know if this is compatible/moddable for UHD media.
OS device name: U:
Product: BD-RW BDR-UD03D
Revision: 1.00
Highest AACS version: 14
many thanks in advance. 8)
