RE:WONT READ DISKS
dwill15
RE:WONT READ DISKS
Post by dwill15 » Thu Sep 05, 2024 1:49 pm
Good morning.,i have my drive all flashed and good to go..when i connect it to my mac it just spins and spins and never shows up in makemkv.....it will finally eject it. I have tried 17 different blu rays and 4ks with the same results. I am lost here. please help
dwill15
Re: RE:WONT READ DISKS
Post by dwill15 » Thu Sep 05, 2024 2:06 pm
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: [redacted]
Firmware version: 1.02
dwill15
Post by dwill15 » Thu Sep 05, 2024 2:07 pm
When i put a disk in it just spins and spins..never shows any contents of the disks .
Post by Billycar11 » Thu Sep 05, 2024 5:23 pm
How is the drive hooked up what adapter are you using if any
dwill15
Post by dwill15 » Fri Sep 06, 2024 12:20 pm
i have it in a enclosure and connected via usb port.
Post by dcoke22 » Fri Sep 06, 2024 2:06 pm
Which enclosure? I have drives in both the OWC enclosure and the Vantec NexStar DX which work fine with my Mac.
dwill15
Post by dwill15 » Fri Sep 06, 2024 2:27 pm
owc enclosure
dwill15
Post by dwill15 » Fri Sep 06, 2024 6:37 pm
it does the same whether i hook it up to a windows machine or my macbook pro...doesnt read the disks...just spins and ejects.
Post by Coopervid » Fri Sep 06, 2024 7:00 pm
Either the laser is dead or the lens is polluted. You can try a CD cleaning disc to clean the lens. Note: CD! A BD cleaning disc might not be recognized and the CD cleaning disc does the same job. If that fails you have a door stop and the laser is dead. To check you can try a DVD or CD which uses the second laser.
