LG BU40N staying on its original firmware
olivr
Post by olivr »
Hello everyone,
I just bought a LG BU40N slim drive on Amazon that I put in an Icy Box external enclosure and connected it via USB-C to a MacBook Pro running Mac OS Ventura (13.6.9)
I followed the ultimate flashing guide and unfortunately the drive stays on its original firmware, even if the flashing procedure ends successfully :(
Here is what I did:
./makemkvcon f -l
Found 1 drives(s)
00: /IOBDServices/BA1A4879
  HL-DT-ST_BD-RE_BU40N_1.04_212005061142_MOFO43B5246
./makemkvcon f -d '/IOBDServices/BA1A4879' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
Reading input file /tmp/HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.04_212005061142_MOFO43B5246
Using USB chipset workaround for Desktop drive handshake
yes
 100% Operation finished
Done successfully
When I open MakeMKV 1.17.7, here is the info about my drive:
Product: BD-RE BU40N
Revision: 1.04
Firmware date: 2120-05-06 11:42
Harware support: Yes
Firmware support: No
Firmware version: 1.04
What did I make wrong?
Re: LG BU40N staying on its original firmware
Look here under 7.
viewtopic.php?f=16&t=19634
"enc" is missing.
olivr
Post by olivr »
Ah! I didn't realize my firmware was an encrypted one... Thanks a lot, it worked!
Revision: 1.04
dmscc
Post by dmscc »
Thank you very much! This helped me a lot as well.
For my understanding: When I used the MK firmware, do I need to flash any other non-encrypted firmware on top of it?
