Foolish Wives - Flicker Alley correct playlist
tuturun
Post by tuturun » Fri Sep 06, 2024 6:19 am
Does anyone have the correct playlist for this? MakeMKV shows nearly 50 fake playlists, I already tried using procmon with VLC but it shows mpls files that are not my STREAM folder
Clooburg2
Re: Foolish Wives - Flicker Alley correct playlist
Post by Clooburg2 » Fri Sep 19, 2025 1:21 am
I need help with the same thing, anyone can help?
Clooburg2
Post by Clooburg2 » Sat Sep 20, 2025 10:03 pm
I tried to send an email with the folder to the support email, but please if anyone knows it'd be helpful, this is my first time around this whole process for blurays
Clooburg2
Post by Clooburg2 » Sat Sep 27, 2025 3:45 pm
Okay okay, I believe I figured it out. I'm not 100% certain, but this seems by far the most likely
01409.mpls title_t41.mkv 16 chapters
4125 2050 505 17508 1850 82020 1050 42052 79142 1840 9670 65731
Good luck guys, the extras should just be all the files that aren't 33GBs, and admins can probably delete my prior messages, sorry if i've been a bit annoying about it.. just my first time having to figure this all out
