Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
kuchenteig
Re: Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested& Makemkv Discount Code
Post by kuchenteig » Thu Aug 29, 2024 7:21 pm
is the Pioneer drive codefree after modding, so I have access to Code A and Code B disks (via Software-Player like VLC, Cyberlink etc.)?
Post by Billycar11 » Thu Aug 29, 2024 8:53 pm
kuchenteig wrote: Thu Aug 29, 2024 7:21 pm Hi,
Yeah the pioneers I sell work with all region Blu-rays .
But not in cyberlink it will work in makemkv and VLC for direct playback.
Will work in cyberlink after you rip
jattsta
Post by jattsta » Fri Sep 06, 2024 5:44 am
alc5440 wrote: Wed Aug 28, 2024 12:52 am Not only is Billy extremely friendly and quick to respond, but he works miracle too. He was able to get my ancient XD05 reading UHD discs, plus it reads almost twice as fast as it did before flashing. I've ripped around 15 discs since with about half of them being UHD and I've had zero issues. He kept me from needing to buy a new drive which was well worth the $25 ($15 if you consider the discount on MakeMKV).
How do I go about doing this to my drive?
Here are my specs:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Firmware date: 2014-12-26
Highest AACS version: 76
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
Post by Billycar11 » Fri Sep 06, 2024 4:09 pm
jattsta wrote: Fri Sep 06, 2024 5:44 am
Here are my specs:
Revision: 3.01
Email that info for the flasher see below
jonburg
Post by jonburg » Mon Sep 09, 2024 11:45 am
hello. Might your drives work for UK/Europe (ABC region) blu ray playback ? I can organise delivery to a US address.
Post by Billycar11 » Mon Sep 09, 2024 4:45 pm
jonburg wrote: Mon Sep 09, 2024 11:45 am hello. Might your drives work for UK/Europe (ABC region) blu ray playback ? I can organise delivery to a US address.
Yes they can rip or unofficial play other region Blu-rays.
Really officially too just change region on the drive to what most of your discs are.
BBQRips
Post by BBQRips » Wed Sep 11, 2024 4:11 am
New to ripping UHD. After having a lot of trouble with a self-flashed LG drive, I headed to the forums and saw people talking about the Pioneer drives from Billy. I wish I had gotten one sooner. All the disks I had trouble with on my LG, my Pioneer was able to handle. Billy is great, responded quick, gave me advice on which drive would work best for what I was doing. Don't hesitate! Get one of his drives!
laines
Post by laines » Fri Sep 13, 2024 12:03 am
Got the Pioneer BDR-213/2213 from Billy arrived today. Didn't want to mess with shelling out extra to replace brick attempts or getting a drive that wasn't as advertised or flashable. Smooth quick transaction throughout and successfully tested everything working as expected. Billy is the way to go if you want to make sure everything goes right the first time.
haborym
Post by haborym » Fri Sep 13, 2024 5:18 pm
I got the drive from Billy super fast after ordering it and when it works it rips (and burns) discs perfectly.
However, I don't know if there is an issue with the drive or with the firmware, but any software in Windows (10) that scans to see the available optical drives will fairly often (33% of the time or so) lock up. It happens with MakeMKV, Imgburn, even EAC and it doesn't matter if there is a disc inside the drive or not. This is not something that has ever happened with any of my previous Plextor, Pioneer, LG, Asus, or Lite-On drives and every time there is a drive cycle (ie eject) it runs the risk of locking up. The only solution is to restart Windows because even if I force stop the software the drive (and any software that scans available drives) remains unusable until the reboot occurs.
Billy has been great trying to help me back and forth but unfortunately I'm out the $274 for what is essentially a coaster and I've had to go back to using my old Asus.
MKV Maker
Post by MKV Maker » Fri Sep 13, 2024 11:51 pm
haborym wrote: Fri Sep 13, 2024 5:18 pm However, I don't know if there is an issue with the drive or with the firmware, but any software in Windows (10) that scans to see the available optical drives will fairly often (33% of the time or so) lock up. It happens with MakeMKV, Imgburn, even EAC and it doesn't matter if there is a disc inside the drive or not. This is not something that has ever happened with any of my previous Plextor, Pioneer, LG, Asus, or Lite-On drives and every time there is a drive cycle (ie eject) it runs the risk of locking up. The only solution is to restart Windows because even if I force stop the software the drive (and any software that scans available drives) remains unusable until the reboot occurs.
I wish it were easy as procuring a Macintosh and using Mac OS. That is my advice for my Pioneer S13J/U-X from Billy never caused me any problems and almost guarantee never will. Curiously your plight is the first I have read in this entire thread. Most persons I believe use Windows in one form or another so perhaps it is particular to your system. Ultimately my advice is to get a Mac and use Mac OS howbeit unrealistic be it may.
haborym wrote: Fri Sep 13, 2024 5:18 pm Billy has been great trying to help me back and forth but unfortunately I'm out the $274 for what is essentially a coaster and I've had to go back to using my old Asus.
That is truly a drag; coasters shall never be that expensive. Good thing it was not the S13J/U-X.
Post by Billycar11 » Sat Sep 14, 2024 2:34 am
MKV Maker wrote: Fri Sep 13, 2024 11:51 pm
i have offered them an exchange even though im pretty sure it just other software all trying to grab the drive at the same time causing issues the new one will likely do the same thing.
i test all drives for 3 hours and all UHD disc types before shipping it did not hang disappear or do anything bad here.
MKV Maker
Post by MKV Maker » Sat Sep 14, 2024 2:38 am
Billycar11 wrote: Sat Sep 14, 2024 2:34 am i test all drives for 3 hours and all UHD disc types before shipping it did not hang disappear or do anything bad here.
Three hours for each drive! Wow! Now I understand why you charge extra for labour. That is an incredible cumulative quantity of time.
derreckjames
Post by derreckjames » Sat Sep 14, 2024 10:45 pm
Love my drive thanks for the help!!
JoeCoole
Post by JoeCoole » Mon Sep 16, 2024 1:23 pm
Hey All/Billy,
I'm new to the forum, so if this has been answered, please just point me to the right post. I'm trying to understand the difference between the Pioneer drives that Billy is selling. They all seem to rip at the same 4x speed. Why pick one over the other?
I have the LG WH14NS40 it is was working fine for the first 2 months, but now it won't detect any disc (BD, DVD, CD, etc.) I put into the drive. I don't think it's my OWC Mercury enclosure so I'm thinking about just getting a Pioneer drive, but not sure of the advantage of one over the other.
TIA,
Joe
MKV Maker
Post by MKV Maker » Mon Sep 16, 2024 1:39 pm
JoeCoole wrote: Mon Sep 16, 2024 1:23 pm I'm trying to understand the difference between the Pioneer drives that Billy is selling. They all seem to rip at the same 4x speed. Why pick one over the other?
I cannot tell you where in this thread but I answered this question with links to Pioneer S13UBK and Pioneer S13J/U-X. If you can find that then most of the question shall be answered.
