MakeMKV integration with Kodi portable?
RebeccaLS071
#1 Post by RebeccaLS071 » Fri Aug 30, 2024 12:05 pm
Heya, I want to play blu-ray discs with Kodi using MakeMKV as the decryptor.
I can get the installed version Kodi to appear in the list of the "Integration" tab in the settings (installed in Program Files folder of C: drive), but not the portable version of Kodi. I'm guessing this is because there isn't any registry traces of the portable version of Kodi compared to the installed version.
Is it possible to have a portable version of Kodi appear in the "Integration" tab of MakeMKV's settings?
I'm trying to use https://github.com/SiL3NC3/PortableRegistrator/ to manually register the portable Kodi but it still doesn't appear in the Integration tab of MakeMKV.
Alternatively, what part of the registry does MakeMKV read to detect installed programs/media players?
Thank you :D
segfaulted
Re: MakeMKV integration with Kodi portable?
#2 Post by segfaulted » Sat Aug 31, 2024 3:55 am
You can manually setup the integration; it's a simple copy/paste of a dll file provided by MakeMKV.
1. Check the folder where MakeMKV is installed (usually C:\Program Files (x86)\MakeMKV ).
2. Look for libmmbd64.dll if you're using a 64bit build of Kodi (or libmmbd.dll if your Kodi build is 32bit).
3. Copy and rename that dll file as libaacs.dll and overwrite the existing libaacs.dll that came with Kodi.
4. Make another copy of that same libmmbd64 / libmmbd file, rename it libbdplus.dll, overwrite the existing dll in Kodi.
RebeccaLS071
#3 Post by RebeccaLS071 » Sun Sep 01, 2024 8:50 pm
Hey thanks for the response!
I carefully followed your instructions, but Kodi can't play the blu ray I want it to.
segfaulted
#4 Post by segfaulted » Mon Sep 02, 2024 10:35 am
Is your installation of MakeMKV registered with a full license, free trial, or beta key? You'll need to make sure it's activated otherwise player integration won't work.
RebeccaLS071
#5 Post by RebeccaLS071 » Mon Sep 02, 2024 11:53 am
Right now it's not activated as the August beta key's expired. I'll re-test when a new key's available :D
cloaked1
#6 Post by cloaked1 » Thu Sep 05, 2024 11:16 pm
I just tried the latest posted beta key and it's still expired. Anyone else having problems with that?
#7 Post by dcoke22 » Thu Sep 05, 2024 11:38 pm
cloaked1
#8 Post by cloaked1 » Sun Sep 08, 2024 5:52 am
Awesome info. Thank you!
RebeccaLS071
#9 Post by RebeccaLS071 » Wed Sep 11, 2024 11:44 pm
Tested with the latest beta key, activated MakeMKV and playing blu-rays with Kodi portable works great!! Thanks!! :D
