BP60NB10 Flasher tool will not start
OTC615
Post by OTC615 »
HI all, I purchased a BP60NBB10, put a 4K disc in, worked. Took the disc out and tried to downgrade the firmware. Drive shown below. I researched, watched videos, read the ultimate downgrade guide; something must be missing.
Based on the video I selected the firmware and when I hit start, the progress bar came up and never moved off 0%. Can someone tell me what I'm doing wrong? Any help would be appreciated. Nothing happened to the drive, it still works. Thank you.
Re: BP60NB10 Flasher tool will not start
follow the guide below the thing your trying to do is outdated
OTC615
Post by OTC615 »
You are a genius and I am just living in your shadow.
Thank you. I was able to update. I figured out that I just needed to remove the encryption so no need to recover. Thank you again.
