Post by RESET_9999 » Sun Sep 01, 2024 9:33 pm
Did you install madvr and lavfilter?
From that log, It fails at the scene cuts detection with madvr
morbius
Post by morbius » Mon Sep 02, 2024 6:49 am
I downloaded the tools.7z package and added the required .exe files from the Dolby Professional tools link, but I missed out a separate installation of LAV filters. The tools folder (in the same directory as the .bat file) includes madvr, but it still looks like I am missing something since the 3-1 workflow is now failing at a later step, see below.
Metadata:
  Mastering display luminance: 0.0001/1000, gamut: 0.68 0.32, 0.15 0.06, 0.265 0.69, 0.3127 0.329
  MaxCLL: 0, MaxFALL: 0 nits
Measurements:
  Frames: 205611, MaxCLL 100%: 1190, 99.9%: 1127, MaxFALL: 955, AvgFALL: 25, AvgFMLL: 577 nits
Reading generate config file...
Parsing madVR measurement file...
Generating metadata: Profile 8.1 (HDR10)...
Generated metadata for 205611 frames
Done.
        1 file(s) moved.
Parsing RPU file...
Exporting scenes list...
Done.
Indexing, please wait... 100%
Writing index... done.
[in#0 @ 000001ff382bb100] Error opening input: Unknown error occurred
Error opening input file D:\DoviScripts\temp.folder77\script.avs.
Error opening input files: Unknown error occurred
Copyright (c) 2013-2024 Dolby Laboratories, Inc. All Rights Reserved
09/02/2024/01:41:28.881000000 CPU: ←[32;1mINFO←[0m ←[KIntel(R) Core(TM) i7-8559U CPU @ 2.70GHz (GenuineIntel) [ mmx sse sse2 sse3 ssse3 sse41 sse42 avx avx2 fma ]
09/02/2024/01:41:28.999000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.049000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.083000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.122000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.162000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.244000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.282000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.341000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.363000000 cm_analyze: ←[31;1mERROR←[0m ←[KUnable Open Sequence 'file:///D:/DoviScripts/temp.folder77/Avengers Assemble_prores.422.mov'. Check file permissions are/or existence
Parsing XML metadata...
Error: The system cannot find the file specified. (os error 2)
File not found - Avengers Assemble_DV.xml
Error: expected value at line 3 column 15
Error: expected value at line 21 column 35
Parsing RPU file...
Post by RESET_9999 » Mon Sep 02, 2024 12:59 pm
it fails when it tries to convert to prores. I don't know why it does that for you sorry.
DylanValenti
Post by DylanValenti » Thu Sep 05, 2024 7:22 am
For the Star Wars films, should we use the p5 to p8 RPUs or should we do the newer generated RPUs
Post by RESET_9999 » Thu Sep 05, 2024 3:19 pm
The ones done in cmv2.9 without trims, yes I always generate new/better cmv4.0 metadata.
pitrako
Post by pitrako » Thu Sep 05, 2024 5:15 pm
Can someone please tell me how to convert truehd atmos to eac joc with atmos?
Gatorman
Post by Gatorman » Fri Sep 06, 2024 5:22 am
AFAIK that isn't possible yet. The Atmos/Object metadata is always lost.
More reasons to collect physical media. Ugoos AM6B+.
pitrako
Post by pitrako » Fri Sep 06, 2024 6:41 am
Ah ok thanks for answering.
Donpoku
Post by Donpoku » Sun Sep 08, 2024 1:29 am
The world of encodes is fascinating indeed. According to this guy W4nk3r has little credibility.
https://docs.google.com/spreadsheets/u/ ... Q/htmlview#
Btw I agree with you and would welcome a list of current top ones apart from your 3 of course.
Post by RESET_9999 » Sun Sep 08, 2024 2:48 am
Yeah, I only list the ones that bake FEL or not and as far as I can tell, the w4nker release I checked looked like decent quality but I don't really care about encoders. I only care about releases that say REMUX.
According to this guy...
Anyway, I'm not sure about this guy's credibility. I do agree with some of his claims but there are no screenshot comparisons and he sounds like he's 12 years old.
morbius
Post by morbius » Mon Sep 09, 2024 12:56 pm
turned out the issue was me relying on the there being an AviSynth folder in the tools.7z package, once I installed avisynthplus the HDR10 conversion to DV completed successfully, albeit it took a very long time on my Intel NUC8i7. At one point I noticed a warning about no CUDA device being available, I guess the conversion had to run without much in the way of hardware acceleration? Is there anything I can do with settings to improve that, or is it a limitation of my not running a full PC rig with an nVidia GPU?
Post by RESET_9999 » Mon Sep 09, 2024 3:54 pm
Yeah, it's already very slow with a GPU, so I can't imagine how long it must be on a CPU. Your only other option is Resolve.
morbius
Post by morbius » Mon Sep 09, 2024 5:44 pm
while it takes a while to convert an HDR10 source via the 3-1 workflow, the results from my first test seem well worth it. One point in this workflow that does not have an automatic option is the prompt for the Mastering Display choice. I'm using the values provided by MediaInfo, is that correct?
Post by RESET_9999 » Mon Sep 09, 2024 6:53 pm
yes
it's because I prefer selecting MDL based on the content's actual brightness.
morbius
Post by morbius » Mon Sep 09, 2024 9:42 pm
you've done amazing work with the toolset, I was happy to make a donation. I just watched my HDR10 copy of Inception after it had been processed via the 3-1 workflow, and found it to be transformed. I've been quite careful in my picture mode configuration on my main OLED display to configure the settings for HDR10 using a Spears and Munsil test pattern, but even with HDR10 dialled in using that test, the DV conversion was so much better.
Is it the case that even with MEL, the DV processing by the display affects how colours are rendered, it's not just about shot-by-shot contrast?
