The Matrix and The Matrix Revolutions
mostlife
Post by mostlife » Tue Jan 07, 2020 3:05 am
I have an UHD BluRay disc of The Matrix (HDR) and The Matrix Revolutions (HDR).
Both return a few uncorrectable scsi errors, after which the ripping stops.
Here is my log:
MakeMKV v1.14.7 win(x64-release) started
Downloading latest SDF to C:\Users\Joannes/.MakeMKV ...
Using LibreDrive mode (v05 id=0FA242DD4D0B)
Title #00201.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00140.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00055.mpls was added as title #0
Title #00054.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00301.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #1
Title #00053.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00004.m2ts was added as title #2
Title #00014.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00002.m2ts was added as title #3
Title #00026.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory F:/rip/The Matrix (1999)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '28981850112'
It is currently still trying to rip, but I suspect it is going to quit with an error very soon.
How do I attach the logs?
Kind regards,
Joannes Wyckmans
Re: The Matrix and The Matrix Revolutions
Post by MartyMcNuts » Tue Jan 07, 2020 3:10 am
mostlife wrote: Tue Jan 07, 2020 3:05 am Hi,
Here is my log:
Kind regards,
Joannes Wyckmans
Can you provide some more info. Let's start with:
1. What drive are you using?
2. How is it connected to PC?
mostlife
Post by mostlife » Tue Jan 07, 2020 3:12 am
Drive is: BD-RE ASUS BW-16D1HT 3.10
Connected over sata...
edit: the matrix reloaded went fine
mostlife
Post by mostlife » Tue Jan 07, 2020 3:49 am
This is my drive info:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: XXXXXXXXXXX
Bus encryption flags: 1F
Highest AACS version: 61
Firmware version: 3.10
Disc Information
Disc is being loaded
PS:
It seems one of the failed matrix discs now ripped..
trying the other one..
Post by MartyMcNuts » Tue Jan 07, 2020 3:57 am
mostlife wrote: Tue Jan 07, 2020 3:49 am This is my drive info:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Disc Information
PS:
Ok, cool. Glad you got one of them working. You may need to give the other disc a good clean before trying again.
mostlife
Post by mostlife » Tue Jan 07, 2020 5:45 am
It still did not work with the last disc, namely revolutions..
I will try again later today or maybe tomorrow.
In the meanwhile I would like to know how to attach a log file...
Post by MartyMcNuts » Tue Jan 07, 2020 6:06 am
mostlife wrote: Tue Jan 07, 2020 5:45 am It still did not work with the last disc, namely revolutions..
I can't remember. Is that a 3 layer disc? Anyway, I think I had trouble with that one the first time. I switched drives and it ripped fine.
Sometimes there are discs that a particular drive just won't read, no matter what you do. This is why most of us have 2 or more drives. If a disc doesn't read properly in drive 1, it generally will in drive 2.
I personally have 3 drives.
My main drive is a BH16NS55 with 1.02.
Drive 2 is a WH16NS60 with 1.00.
Drive 3 is a BH16NS55 cross-flashed to an ASUS BW-16D1HT 3.02.
Post by Billycar11 » Tue Jan 07, 2020 9:52 am
MartyMcNuts wrote: Tue Jan 07, 2020 6:06 am
its a dual layer BD 66 this site https://www.blu-ray.com/movies/The-Matr ... ay/208210/ is really useful for seeing what disk type it is
Post by MartyMcNuts » Tue Jan 07, 2020 10:11 am
Billycar11 wrote: Tue Jan 07, 2020 9:52 am
LOL... I use blu-ray.com all the time and didn't think to check the disc info. Anyway, here is the Disc Info for The Matrix Trilogy, which is what I have.
Discs
4K Ultra HD
Blu-ray Disc
Nine-disc set (3 BD-100, 3 BD-25, 3 BD-50)
Here is the link. https://www.blu-ray.com/movies/The-Matr ... ay/212786/
Post by Billycar11 » Tue Jan 07, 2020 11:34 am
MartyMcNuts wrote: Tue Jan 07, 2020 10:11 am
Hmm I see that's weird that a different set is on a different format bd I would think they are the same even us version of trilogy is bd 100 and standalone is bd 66 I wonder what one is """"Better""" lol
Post by MartyMcNuts » Tue Jan 07, 2020 11:08 pm
Billycar11 wrote: Tue Jan 07, 2020 11:34 am
Just for curiosity's sake, I went and got my trilogy out of the cupboard and loaded each UHD into MakeMKV.
The Matrix
Data capacity: 64.83 Gb
Disc type: BD-ROM UHD
Number of layers: 3
The Matrix Reloaded
Data capacity: 86.33 Gb
Number of layers: 3
Data capacity: 66.23 Gb
Number of layers: 3
agneva
Post by agneva » Fri Jan 10, 2020 12:20 pm
i´ve seen there are 3 titels on the Matrix 4K Bluray, each ~65GB.
is one HDR and one Dolbyvision ?
Couldn´t see differences in video info.
mostlife
Post by mostlife » Tue Apr 27, 2021 12:07 pm
I have the matrix with 58GB average. It has dolby vision and Thru HD / atmos 7.1 audio.
It is the one for Belgium, luxembourg and dutch market(BENELUX). Those 2-3 markets usually have a shared printing in french and dutch. None of them rip. The quit at about 24GB
Neo369
Post by Neo369 » Thu Sep 05, 2024 12:26 am
hi could you send me a Google drive with all the 4K Matrix thank you :D
Post by Woodstock » Thu Sep 05, 2024 1:32 am
Shouldn't be necessary, as the disk rips. You just need to select the correct track for what you want, as mentioned above.
