WH16NS60 Firmware
danmanx
WH16NS60 Firmware
Post by danmanx » Wed Sep 04, 2024 9:49 am
Could anyone know what's this issue?
Makemkv shows "LibreDrive Enabled",
OS device name: H:
Product: BD-RE WH16NS60
Revision: 1.00
Serial number: [redacted]
Firmware date: 2117-04-25 17:56
Highest AACS version: 81
Firmware version: 1.00
but when I rip UHD discs, it shows below, did i mess up something? I can rip UHD discs perfectly through this drive when the keys available. For not supported UHD, the generated discatt.dat file under dump tgz doesnt contain VID...
I don't know if it's because of the firmware, but I also have error issue when trying flashing....
Debug log started at Sun Sep 01 03:32:34 2024 , written by MakeMKV v1.17.6 win(x64-release)
001005:0000 MakeMKV v1.17.6 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\danmanx/MakeMKV_log.txt
SDF  v098: HL-DT-ST_BD-RE__WH16NS60_1.00_211704251756_103HAVN29291
005072:0000 Backing up disc into folder "file://C:/Users/danmanx/Desktop/backup/A moment of romance"
DEBUG: Code 2147483648 at WKYQi`r2nRn]/W8S:121265499
DAFD=PAAAADAAAAEABDQgEFwECAQ==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..046D3E117CDEE7AAF9A44046B3001C6259E to device 'SPTI:\Device\CdRom2'
001003:0020 DEBUG: Code 0 at (V0PO7]PqU(,OTLVs:213130766
001003:0020 DEBUG: Code 0 at a%48&'jm4Zb*$m{*oY:121263429
001003:0020 DEBUG: Code 0 at a%48&'jm4Zb*$m{*oY:213130789
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..026F8C23267068FB2A99716083A3D39EBD8 to device 'SPTI:\Device\CdRom2'
001003:0020 DEBUG: Code 1 at a%48&'jm4Zb*$m{*oY:213130789
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0475573C54B1FC2785B73A352B8E8B3E52A to device 'SPTI:\Device\CdRom2'
001003:0020 DEBUG: Code 2 at a%48&'jm4Zb*$m{*oY:213130789
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0DCD12CD7EBDB1CF0CBD8A03958889E8516 to device 'SPTI:\Device\CdRom2'
001003:0020 DEBUG: Code 3 at a%48&'jm4Zb*$m{*oY:213130789
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0A53CBA89CBCDF6B681ED113E8256450785 to device 'SPTI:\Device\CdRom2'
001003:0020 DEBUG: Code 4 at a%48&'jm4Zb*$m{*oY:213130789
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..039375979BDAAA6154C81000DA9B88BC0F0 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0FF8EBE4183D1A0A40446820ADED99FFA78 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0A5EF9BEC944201741F812EE54C88FB73A1 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..005474D7A17A13001A297754657E84E51E4 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0994863DDBD08045E016AD54C8D967DB911 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..00879EBCDED90FC69F900F4E356437DF38E to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0A85547A9224E886BEA87039881C7A76295 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..08FF176AA6FDE655CD49AF514CF2C49A0F9 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..057D053E84902BBB3A430238276850DB202 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..07FA60C21053D87B70F66AFBA5F33771FF9 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0181D38BCB8C3C339B8994F8FAA23C6BFA4 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..036EB91D74EAD0A4A0F7CB7934034008A22 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0EB6BA898587E432FC0E88EB91E4493CAE4 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0028FE69F098508EAB9D9E26E3255ECD492 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..00A076F9F87FB2A798AD182659472B85578 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0B97B464646D6FFE8A0DE1CB4039AD584D0 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom2'
DEBUG: Code 0 at (V0PO7]PqU(,OTLVs:213130306
001003:0020 DEBUG: Code 0 at a%48&'jm4Zb*$m{*oY:121264395
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..04FC26F865DC22A8366E145093FB7C13040 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..026E2656460D753CD85BBD5DCE6E6002647 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..09A16C104362ECF9FB7CA11E52D3B01E4D5 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0BF43EB321322FA69D9E6AA8281E0563B10 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0EFD361A6FDF363D44A6D333D2085CE7036 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0E0986CC8125C99E128D2E71A09F94F64D5 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0F50C4471CC43692CF025D03659316625AF to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..03CB1467611425DF74A0AA05539BA9C85BB to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..09B2A7FB9128C0D681299104ED08DF9526D to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0CEDE9B01E534908DD77C29DB723EA51CB3 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..00B3CA5690CFC99E410D1D6E921C4D0452A to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0F42CC752A8B526C24440426D08E3C3410A to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0DA204053349105C3F0144F9E0E5FB6A1D1 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..08B6772B9E270270A3FF7D18E2CB635B431 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..07D0B154D6078559F76ACE3735514511142 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..075309B0E7AAB73500BAE259FAE0A3BE20E to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0E686668C5492F305F7634417B2F78C2956 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..05A37398E612E0B7ABF4250F9056ADAFC6F to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0FAA815627EAEC1ECA83D0396DAB9B19AAD to device 'SPTI:\Device\CdRom2'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Re: WH16NS60 Firmware
Post by Billycar11 » Wed Sep 04, 2024 3:58 pm
Usually the only things that will cause this is makemkv not downloading the sdf and hk or the drive not fully passing through in something like a sandbox or vm.
Easiest thing to do first is try a VPN and see if it downloads.
danmanx
Post by danmanx » Wed Sep 04, 2024 4:12 pm
Hi, I always turn vpn on. When the hk updated, it would download, and then could rip UHD properly. So I feel strange about it.
