AACS Question
alumpkin
AACS Question
Post by alumpkin » Tue Sep 03, 2024 9:18 pm
I am relatively new to MakeMKV, so this may be an ignorant question.
In the past, I have not had any issues with using MakeMKV for the most part. I recently have started having issues and it appears they are related to AACS protection.
This is what I am seeing in MakeMKV:
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: [redacted]
Highest AACS version: 76
Firmware version: 1.05
Disc Information
Label: HARD TARGET
Timestamp: 2021-10-18 14:10:37
Protection: AACS v76
Data capacity: 38.61 Gb
Disc type: BD-ROM
Number of layers: 2
When I try to open the disc, it says it uses newer AACS protection and fails to open. But it appears on my Drive Information AACS stat line that I can do the same 76 that the disc has. I made sure that my MakeMKV is fully updated.
What am I missing?
Ezatoka
Re: AACS Question
Post by Ezatoka » Wed Sep 04, 2024 7:17 am
Do you have internet access enabled in the preferences, so it can download newest key informations? Or is the download maybe blocked?
I think that would be visible in the debug log file.
Re: AACS Question
Post by dcoke22 » Wed Sep 04, 2024 2:30 pm
As I understand it, the line about 'Highest AACS version' in the drive information section is merely stating the highest version of AACS that the drive has seen. It isn't making a statement about the drive's capabilities.
That your drive is LibreDrive enabled, however, is making such a statement. As such, I would expect that drive to be able to rip that blu-ray without a problem.
The only thing odd I notice is the Ultimate UHD Drives Flashing Guide says to flash your drive (a WH16NS40) directly to WH16NS60 1.02mk firmware.
WH16NS40 on any Firmware directly to > WH16NS60 1.02MK
Those firmware recommendations are based on years of accumulated data about which firmware is best for ripping. I don't know if that'll change the the results in your case, but it might.
alumpkin
Re: AACS Question
Post by alumpkin » Wed Sep 04, 2024 3:57 pm
Thanks for the replies.
I guess this is closed though because I reinstalled MakeMKV this morning, restarted my computer, and it is working again. Weird...
Anyway, if I run into any more issues, I will certainly be trying to flash back to 1.02mk.
Thanks again!
Re: AACS Question
Post by Billycar11 » Wed Sep 04, 2024 3:57 pm
Usually the only things that will cause this is makemkv not downloading the sdf and hk or the drive not fully passing through in something like a sandbox or vm.
Easiest thing to do first is try a VPN and see if it downloads.
alumpkin
Re: AACS Question
Post by alumpkin » Wed Sep 04, 2024 6:13 pm
Ok, so the MakeMKV re-install did not work over the long term. After one save, it failed again with the same AACS errors.
I tried the WH16NS60 1.02mk firmware and that did not work.
I then tried the WH16NS40 1.03mk firmware, and it is working thus far.
Re: AACS Question
Post by Billycar11 » Thu Sep 05, 2024 5:25 pm
alumpkin wrote: Wed Sep 04, 2024 6:13 pm Ok, so the MakeMKV re-install did not work over the long term. After one save, it failed again with the same AACS errors.
That makes no sense unless your on Linux
