Hi community,
there is the following problem:
I got one bluray-disc, I use "MakeMKV" to convert the bluray to a MKV file. At the beginning of the film (orininal bluray) there is a marquee and I'm able to see the marquee in german. PowerDVD shos me the german marquee. At the beginning of the film (ripped MKV) i see the same marquee, but this time the marquee is in english. Waht can I do to change the settings? I think that this is not a subtitle issue because it is the video, the marquee.
Thx
Martin
MKV with GERMAN marquee
setarip_old
Re: MKV with GERMAN marquee
Hi!
What is the title and region of your original, commercial Blu-ray disc?
Which did you select, German or English, as the audiostream?
Commercial Bluray Box:
Band of Bothers
Band of Bothers
audiostream is german,
in fact MakeMKV shows 6 titles, every title has the same audiostreams, subtitles...i decided the first title and then there is the wrong marquee
but, when i select the second title ***wohooo*** there is the right marquee
OK, is there a way you can find out which title has the "german video"...in this case, it is fine, but for the following blurays...
robpdotcom
If you play it in a standalone player you can probably see which title goes with each language.
