Pioneer BDR-UD03 UHD possibility
TheVM
Re: Pioneer BDR-UD03 UHD possibility
Post by TheVM »
Coopervid wrote:
Sun Sep 01, 2024 6:52 pm
TheVM wrote:
Thu Aug 29, 2024 11:09 pm
Coopervid wrote:
Tue Aug 27, 2024 5:31 pm
Pm sent.
Hi Coopervid!
I stumbled on this topic and i'm wondering if you could help me flash my drive:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 35
Drive platform: RS8511
Firmware version: 1.14
Check your PM.
Thanks! It works! :-)
raven9mm
Post by raven9mm »
Coopervid wrote:
Sun Sep 01, 2024 6:43 pm
raven9mm wrote:
Sun Sep 01, 2024 7:39 am
Hi Coopervid, Looking for UHD firmware for below drive, Thank you very much in advance!
OS device name: H:
Product: BD-RW BDRUD03AS
Revision: 1.10
Serial number:
Firmware date: 2017-04-18
Highest AACS version: 68
Firmware version: ID23
PM is coming.
Got it done, no issues whatsoever, UHD now works! Thank you for prompt reply, and for simple and very effective instructions and files!
SneakyGit wrote:
Sat Aug 31, 2024 7:57 pm
Coopervid wrote:
Thu May 02, 2024 10:45 am
PM sent.
My apologies,
Apparently I missed your response, and you have deleted your PM.
emails always open and does not expire
i understand cooper is limited the amount of messages he can have we all are so thats why he wants to always stay below the limit
i get around this by using email see below
McZion
Post by McZion »
Coopervid wrote:
Sun Sep 01, 2024 6:49 pm
McZion wrote:
Wed Aug 28, 2024 10:02 pm
Hi Coopervid!
I was checking some forum topics and different instructions and came to this topic, where I see I can have my Pioneer BDR-US03 (in ASUS SBW-06D5H-U enclosure) flashed to be UHD friendly.
I would greatly appreciate it if you could send me the firmware I need to enable UHD disk reading. Here is my info:
OS device name: F:
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Firmware date: 2018-08-22
Firmware version: E101/ID26
Also, I would like to clarify - in case of problems, will it be possible to return to my drive's original firmware after flashing the UHD-friendly firmware?
Thank you in advance!
PS: I have enabled notifications, so I will for sure see your response :)
Check your PM.
Thank you very much! Unfortunately, I cannot answer via PM yet, but I wanted to say one more thing (if I shouldn't post this, please let me know).
It looks like after flashing, the drive pretends to be entirely a BDR-UD04 drive (even the part about the Asus enclosure disappears), and MakeMKV says that the firmware type is still "Original (unpatched)".
I tried and loaded the disk into PowerDVD, and it looks like the player was trying to read it! I have even seen a message in the form of "Initializing UltraHD disk playback for the first time...". But in the end, everything failed because not all of the requirements for 4K UHD disk playback were met on my PC.
Am I understanding everything correctly, with this kind of firmware I can legally play 4K UHD disks on a PC (when all requirements are met + licensed PowerDVD Ultra of specific version)?
TheoDW
Post by TheoDW »
Coopervid wrote:
Tue Aug 13, 2024 5:15 pm
PM is coming.
Finally managed to get around a Windows computer to do the update, worked flawlessly. Thanks for the help!
McZion wrote:
Sun Sep 01, 2024 9:56 pm
Hi Coopervid!
OS device name: F:
Manufacturer: ASUS
Revision: E101
Check your PM.
No, you can't use PowerDVD as the drive is not a real UHD drive. You can play UHD discs using MakeMKV as the on-the-fly decrypter and an unofficial player such as VLC among the many others. Just not PowerDVD!!
SneakyGit
Post by SneakyGit »
Billycar11 wrote:
Sun Sep 01, 2024 9:17 pm
Thanks Billy ...
McZion
Post by McZion »
MartyMcNuts,
This is what MakeMKV shows me about the drive after flashing:
OS device name: F:
Product: BD-RW BDR-UD04
Revision: 1.14
Highest AACS version: 61
Drive platform: RS8A10
Basically, only the serial number is the same as it was before flashing - most of the other info has changed.
How does PowerDVD know that this is not an official UHD drive? And at which step of opening the disk PowerDVD will say to me that it is not supported?
McZion wrote:
Mon Sep 02, 2024 1:00 pm
MartyMcNuts,
OS device name: F:
Revision: 1.14
PowerDVD needed the official SGX chain. Also with an original UHD drive. You can either decrypt the UHD to folder or MKV and then play this using PowerDVD. If you want to play directly from the disc you need a real-time decryptor like XReveal.
McZion
Post by McZion »
Coopervid, yes, I know.
I have everything needed according to Cyberlink's and Intel's FAQs, currently, I do not have the perfect PC (laptop) for playback, but the one I can test with before moving forward (if that's possible, of course). It has an Intel Core i5-10210U CPU with Intel SGX, and at some point, PowerDVD installed some plugins for SGX that are needed for playback, so no problem here. Even Cyberlink's UHD advisor says every mandatory part in my setup meets the requirements (just the SGX module gives a known error for modern hardware, which is not an error actually). I might get myself later an Intel NUC for some tasks, so I will get one with Intel SGX and HDMI 2.0.
Yes, I entered the UHD disk playback zone a bit late. But I still believe I can do it, I mean legal UHD playback on the PC. Just it is not a priority now, and if I can rip UHDs or decrypt them in a non-official way, that would be a good workaround at the time of no legal ways to play UHD disks on PC.
To be honest, the only requirement in my test that is not met - the PowerDVD 20/21/22 Ultra license key (because it cannot be officially bought from the official website anymore).
Right now, I'm just interested in why my flashed drive cannot be recognized by PowerDVD correctly. So I can understand if I need to find a UHD official drive when possible, or if I can use the one flashed recently.
PS: I am an experienced user with firmware - in the past, I have worked with BIOS firmware and programmers, and even fixed the Intel TXE region on a faulty device. That's why I am always interested in "how it works". Maybe one day I will investigate the possibility of directly accessing the drive's firmware using a programmer, but not now :D
You don't understand. SGX playback has beeen switched off by Cyberlink and also the newest versions of PowerDVD even don't support UHDs anymore. So stop here. Rip the disc or use an on-the-fly-decryptor like XReveal. And you have to use an older version of PowerDVD. The newest ones are crippled regarding UHDs.
McZion
Post by McZion »
Coopervid, so you mean that even if I find a license for PowerDVD 22 Ultra (theoretically, there are resellers, but not verified yet), install the build that was before the patch that removed UHD playback (probably PD 22 build 3418, and disable updates), I won't be able to play UHD disks?
I might not fully understand, what's wrong with Intel SGX, as it is a built-in feature in the CPU and works in Win10 (not Win11), and why older "supported" versions of PowerDVD cannot work properly.
If you have any posts on the forum that explain this or some external links (you can PM them to me, if you still have the capacity), I would appreciate it. Just I have a feeling that I am going off-topic...
I might think that Cyberlink will not connect to some of their servers, or that fetching decryption keys is disabled on the server level, not the application. That would make sense to me, why even older versions of PD won't work now.
PS: Thank you for XReveal. Looks promising. I will look into that later.
McZion wrote:
Mon Sep 02, 2024 7:18 pm
SGX support has been turned off at the server side. No legal way anymore to play UHDs on a computer. This was extensivly discussed in the Redfox forum but that forum is down and so no external links.
If on-the-fly decryption is enabled, older PowerDVD versions will work. Newer ones don't even play decrypted UHDs anymore.
McZion
Post by McZion »
Coopervid, that's sad :(
So this means that people who met all the requirements and successfully played UHDs in PowerDVD up until Nov 2023, now cannot do that anymore?
OK, thank you very much for explaining! All hope now for those people and their apps, which decrypt new UHDs and let others play those disks as if it was officially supported :lol:
And again, thank you for helping me with my drive. Now I have a potential way of playing my UHDs, just need to take a look at XReveal :wink:
McZion wrote:
Mon Sep 02, 2024 7:43 pm
Yes, now you are up-to-speed with all restrictions even owners of a bought UHD disc are facing.
