Possible to flash this drive
PJD1984
#1 Post by PJD1984 » Sun Sep 01, 2024 3:06 pm
Hi is it possible to flash this drive its Hitach LG BP55EB40 SVC EB52 Manufactured March 2024? I was a bit of a lottery when I purchased from Amazon which one I would get. Looking through the guides, it doesn't seem it will be. Can always return.
Any help wwould be appreciated
Re: Possible to flash this drive
#2 Post by Billycar11 » Sun Sep 01, 2024 4:44 pm
Email me the makemkv drive info section.
Lashrar
#3 Post by Lashrar » Tue Sep 03, 2024 8:19 pm
Hi, I have the same drive except for the build month is May 2024. Is it usable and which firmware(s) would I need to flash it to?
Thanks for the help!
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: HL-DT-ST
Produkt: BD-RE BP55EB40
Revision: 1.03
Firmware-Datum: 2121-07-08 16:06
Markierungen der Bus-Verschlüsselung: 17
#4 Post by Billycar11 » Wed Sep 04, 2024 12:15 am
Lashrar wrote: Tue Sep 03, 2024 8:19 pm Hi, I have the same drive except for the build month is May 2024. Is it usable and which firmware(s) would I need to flash it to?
Produzent: HL-DT-ST
Revision: 1.03
follow the guide below for BP50
or email me
matti46
#5 Post by matti46 » Sat Dec 28, 2024 3:29 pm
Hi
I have also this same drive. SVC is EB52. I tried to look trough the forum to find confirmation for the correct flashing procedure, but didn't find it. I just don't want to brick my drive.
So is the correct prosedure for this drive the same as mentioned in SDFtool flasher's page?
viewtopic.php?f=16&t=22896
For the moment, to flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follw the steps below:
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
Now for the crossflash:
2. Select the RECOVERY option and in the pop up, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select the BP60NB10 1.00-MK or BU40N 1.00 firmware in the normal drop box.
4. Click START
My drive info is as follows:
OS device name: H:
Product: BD-RE BP55EB40
Revision: 1.03
Serial number: *REDACTED*
Firmware date: 2121-07-08 16:06
#6 Post by MartyMcNuts » Sun Dec 29, 2024 10:29 am
matti46 wrote: Sat Dec 28, 2024 3:29 pm Hi
4. Click START
OS device name: H:
Revision: 1.03
Yep, same process. BU40N 1.00 is recommended.
My All you need firmware pack doesn't include a BP55EB40 firmware but you should be able to use the BP50NB40 NB50 1.03-MK firmware for the first step. Otherwise, you could download either Billy's all you need firmware pack or the MK firmware pack from: viewtopic.php?p=74718#p74718 (toward the bottom of first post) if you want to use the BP55EB40 firmware for the first step.
