DylanValenti wrote: Sat Aug 31, 2024 5:05 am
Very interesting! Same deal for Furiosa? That one is much more static than KotPotA
not as much work as the apes but still very dynamic.
jayper
Post by jayper »
DylanValenti wrote: Sat Aug 31, 2024 3:54 am
jayper wrote: Sun Aug 25, 2024 3:40 pm
DylanValenti wrote: Sat Aug 24, 2024 8:08 pm Yep. Ended up figuring that out too last night. Demuxed each segment with tsmuxer, combined BL and EL with your tool and then appended them in mkvtoolnix. Really odd this happened though, I’ve never encountered an error with RPUs using makemkv and I’ve ripped so many discs.
Does MakeMKV throw an error when this happens? Or did you only notice during playback?
Didn’t even get far enough for playback. I check all my RPUs because I’ve been burned before (early framestore hybrids, yuck). But no, makemkv didn’t throw an error, so that’s not great.
Forgive the likely ignorant question, but how do you check your RPUs?
valington
Post by valington »
RESET_9999 wrote: Tue Aug 27, 2024 3:14 pm
Or are they smart enough to actually be baking the FEL into the BL?
I've listed the groups that bake FEL and those that don't. I did not check all of them but most didn't encode FEL to P8 correctly.
does that mean it's likely ok if an encoder ditched the FEL and just went with the BL?
yes
It looks like Pulp Fiction's FEL is only 3847 kbps. Does the bitrate of the FEL generally correlate to how "important" it is? IE - this relatively low bitrate FEL isn't doing much and can probably safely be thrown out, whereas the much higher 13877 kbps bitrate of The Truman Show means it's far more important to make sure the FEL is properly dealt with and not thrown away. Is that correct?
the EL bitrate doesn't mean much. I've seen 18mb/s EL that adds nothing to the BL.
RESET please give information how can i install ce-ng for s905x4 dune homatics for true -tv led and true dolby vision fel ? i dont have experirnce in it
valington wrote: Sun Sep 01, 2024 2:38 pm RESET please give information how can i install ce-ng for s905x4 dune homatics for true -tv led and true dolby vision fel ? i dont have experirnce in it
No idea, ask on the CE forum.
https://discourse.coreelec.org/t/ce-ng- ... 05x4/50953
staknhalo
Post by staknhalo »
DylanValenti wrote: Sat Aug 31, 2024 3:53 amYou can just grab the web-dl for mando and do the hybrid yourself for the last ep of s2. I also noticed it was out of sync back when I put on on my server, so I did this. Sync is fine now, checked.
I'm just gonna realign the RPU already there with Reset's tools when I get around to it
RESET_9999 wrote: Sat Aug 31, 2024 4:55 amImage
Man, imagine if every movie got that much love and care :/
valington
Post by valington »
RESET_9999 wrote: Sun Sep 01, 2024 3:36 pm
Thank you
morbius
Post by morbius »
EDIT: I hadn't installed LAV filters, the script didn't warn me about that, but after installation the script seems to be running ok.
I'm trying my first attempt at converting an HDR10 mkv to DV using the dovi_scripts. As far as I can tell, all the required .exe files are in the tools folder. The following workflow has no warning messages about missing .exe files, but fails with the messages copied below. Grateful for any suggestions.
3-1-n-20-a
Measuring the letterbox...
Done
--> left border: 0
--> right border: 0
--> top border: 42
--> bottom border: 42
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'D:\DoviScripts\temp.folder77\BL.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
LAV Splitter Source not found.
Reading generate config file...
Parsing madVR measurement file...
Error: The system cannot find the file specified. (os error 2)
Parsing RPU file...
madvr failed to make the scene cuts
Did you install madvr and lavfilter?
From that log, It fails at the scene cuts detection with madvr
morbius
Post by morbius »
I downloaded the tools.7z package and added the required .exe files from the Dolby Professional tools link, but I missed out a separate installation of LAV filters. The tools folder (in the same directory as the .bat file) includes madvr, but it still looks like I am missing something since the 3-1 workflow is now failing at a later step, see below.
Metadata:
  Mastering display luminance: 0.0001/1000, gamut: 0.68 0.32, 0.15 0.06, 0.265 0.69, 0.3127 0.329
  MaxCLL: 0, MaxFALL: 0 nits
Measurements:
  Frames: 205611, MaxCLL 100%: 1190, 99.9%: 1127, MaxFALL: 955, AvgFALL: 25, AvgFMLL: 577 nits
Generating metadata: Profile 8.1 (HDR10)...
Generated metadata for 205611 frames
Done.
        1 file(s) moved.
Parsing RPU file...
Exporting scenes list...
Done.
Indexing, please wait... 100%
Writing index... done.
[in#0 @ 000001ff382bb100] Error opening input: Unknown error occurred
Error opening input file D:\DoviScripts\temp.folder77\script.avs.
Error opening input files: Unknown error occurred
Copyright (c) 2013-2024 Dolby Laboratories, Inc. All Rights Reserved
09/02/2024/01:41:28.881000000 CPU: ←[32;1mINFO←[0m ←[KIntel(R) Core(TM) i7-8559U CPU @ 2.70GHz (GenuineIntel) [ mmx sse sse2 sse3 ssse3 sse41 sse42 avx avx2 fma ]
09/02/2024/01:41:28.999000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.049000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.083000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.122000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.162000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.244000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.282000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.341000000 plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
09/02/2024/01:41:29.363000000 cm_analyze: ←[31;1mERROR←[0m ←[KUnable Open Sequence 'file:///D:/DoviScripts/temp.folder77/Avengers Assemble_prores.422.mov'. Check file permissions are/or existence
Parsing XML metadata...
File not found - Avengers Assemble_DV.xml
Error: expected value at line 3 column 15
Error: expected value at line 21 column 35
Parsing RPU file...
it fails when it tries to convert to prores. I don't know why it does that for you sorry.
DylanValenti
Post by DylanValenti »
For the Star Wars films, should we use the p5 to p8 RPUs or should we do the newer generated RPUs
The ones done in cmv2.9 without trims, yes I always generate new/better cmv4.0 metadata.
pitrako
Post by pitrako »
Can someone please tell me how to convert truehd atmos to eac joc with atmos?
Gatorman
Post by Gatorman »
AFAIK that isn't possible yet. The Atmos/Object metadata is always lost.
pitrako
Post by pitrako »
Ah ok thanks for answering.
