MakeMKV integration with Kodi portable?
RebeccaLS071
Post by RebeccaLS071 »
Heya, I want to play blu-ray discs with Kodi using MakeMKV as the decryptor.
I can get the installed version Kodi to appear in the list of the "Integration" tab in the settings (installed in Program Files folder of C: drive), but not the portable version of Kodi. I'm guessing this is because there isn't any registry traces of the portable version of Kodi compared to the installed version.
Is it possible to have a portable version of Kodi appear in the "Integration" tab of MakeMKV's settings?
I'm trying to use https://github.com/SiL3NC3/PortableRegistrator/ to manually register the portable Kodi but it still doesn't appear in the Integration tab of MakeMKV.
Alternatively, what part of the registry does MakeMKV read to detect installed programs/media players?
Thank you :D
segfaulted
Re: MakeMKV integration with Kodi portable?
Post by segfaulted »
You can manually setup the integration; it's a simple copy/paste of a dll file provided by MakeMKV.
1. Check the folder where MakeMKV is installed (usually C:\Program Files (x86)\MakeMKV ).
2. Look for libmmbd64.dll if you're using a 64bit build of Kodi (or libmmbd.dll if your Kodi build is 32bit).
3. Copy and rename that dll file as libaacs.dll and overwrite the existing libaacs.dll that came with Kodi.
4. Make another copy of that same libmmbd64 / libmmbd file, rename it libbdplus.dll, overwrite the existing dll in Kodi.
RebeccaLS071
segfaulted wrote: Sat Aug 31, 2024 3:55 am You can manually setup the integration; it's a simple copy/paste of a dll file provided by MakeMKV.
Hey thanks for the response!
I carefully followed your instructions, but Kodi can't play the blu ray I want it to.
segfaulted
RebeccaLS071 wrote: Sun Sep 01, 2024 8:50 pm Hey thanks for the response!
Is your installation of MakeMKV registered with a full license, free trial, or beta key? You'll need to make sure it's activated otherwise player integration won't work.
RebeccaLS071
segfaulted wrote: Mon Sep 02, 2024 10:35 am
Right now it's not activated as the August beta key's expired. I'll re-test when a new key's available :D
cloaked1
Post by cloaked1 »
I just tried the latest posted beta key and it's still expired. Anyone else having problems with that?
cloaked1 wrote: Thu Sep 05, 2024 11:16 pm I just tried the latest posted beta key and it's still expired. Anyone else having problems with that?
cloaked1
Post by cloaked1 »
dcoke22 wrote: Thu Sep 05, 2024 11:38 pm
Awesome info. Thank you!
RebeccaLS071
Tested with the latest beta key, activated MakeMKV and playing blu-rays with Kodi portable works great!! Thanks!! :D
