Thank you for that info. I tried that and it worked. I have created a symlink in the .MakeMKV folder pointing to the keydb file it creates and set the synchronize batch file to run daily. I appreciate the assist on this.
Wonka 4k Dump Submitted
Re: Wonka 4k Dump Submitted
It worked! Thanks again.
This worked perfect for me, thank you
MKB20_v77_Wonka_16A0.tgz dump submitted from today's UK UHD release.
Is there a fix that I'm missing? i have a problem still
MKB20_v77_Wonka_16A0 - Dump file sent today
Obsessive compulsive ripper and collector since finding Make MKV!
Converting nearly 1,200 Blu Rays and UHD in 1:1 format to a Plex library serviced by Infuse.
Heads up for UK users - the 16A0 UHD disc is now decrypting for me - it wasn't yet when I had last tried on Wednesday.
MKB20_v77_Wonka_8E40.tgz submitted
The keydb-trick does not work for me.
2024-03-18
Now works.
2024-03-18
Now works.
Just bought the combo 4KUHD/Blu-ray of "Willy Wonka & The Chocolate Factory" (version with Gene Wilder)
No problem with the Blu-ray
However MakeMKV rejects the 4K version "unknown key"
Of course, the keydb.cfg file has been downloaded and stored in the MakeMKV folder
Any help would be appreciated
Did you email your dump file to svq@makemkv.com? Post the name of the dump file on the forum.Macguy wrote: ↑Thu Aug 29, 2024 5:57 pmHi,
UHD FAQ
Thanks for the tip.
Dump file has just been emailed
MKB20_v76_Willy_Wonka_and_the_Chocolate_Factory_5D29.tgz
